;* distance and bearing label for lines
(graphscr)
(prompt "\nloading. . .")
;convert radians to degrees
(defun rtd (R) (/ (* R 180.0) pi))
(defun C:brg2 ()
;input for line notations
(setq P1 (getpoint "\nfirst point: "))
(while
(setq P2 (getpoint p1 "\nsecond point: "))
(setq T1 "text height: <default = "
T2 ">: "
T3 (getvar "textsize")
);setq
(terpri)
(setq TH (getreal (strcat T1 (rtos T3 2 2) T2)))
(if (= TH nil)
(setq TH t3))
;determine if bearings are true north, south, east, or west
(defun nsew ()
(if (and (= (car P1) (car P2))
(< (cadr P1) (cadr P2)))
(setq BNG "north")
);if
(if (and (< (car P1) (car P2))
(= (cadr P1) (cadr P2)))
(setq BNG "east")
);if
(> (cadr P1) (cadr P2)))
(setq BNG "south")
);if
(if (and (> (car P1) (car P2))
(setq BNG "west")
);if
);defun
;place text on line
(setq AA (angle P1 P2)
DS (distance P1 P2)
P3 (polar P1 AA (/ DS 2.0))
AA1 (strcat (rtos (/ DS 12.0) 2 2) "'")
);setq
;calculate bearing from coordinates and format for printing
(defun bearing ()
(setq O (- (car P2) (car P1))
T (- (cadr P2) (cadr P1))
AZMTH (/ (* (atan (/ O T)) 180.0) pi)
A (abs AZMTH)
D (fix A)
M (* 60 (- A D))
S (* 60 (- M (fix M)))
M (fix M)
);setq
(if (= "60" (rtos s 2 0)) (setq M (+ 1 m)))
(if (= "60" (rtos s 2 0)) (setq S 0))
(if (= "60" (rtos m 2 0)) (setq D (+ 1 d)))
(if (= "60" (rtos m 2 0)) (setq M 0))
(if (< (cadr P2) (cadr P1)) (setq G "s") (setq G "n"))
(if (< (car P1) (car P2)) (setq H "e") (setq H "w"))
(setq BNG (strcat G ""
(if (< D 10) (strcat "0" (rtos D 2 0)) (rtos D 2 0)) "%%d"
(if (< M 10) (strcat "0" (rtos M 2 0)) (rtos M 2 0)) "'"
(if (< S 10) (strcat "0" (rtos S 2 0)) (rtos S 2 0))
"''" "" H))
);setq
;bearing and distance on line
(if (or (= 0 (- (car P1) (car P2)))
(= 0 (- (cadr P1) (cadr P2))))
(nsew) (bearing))
(command "text" "m"
(polar P3
(rem (+ AA (/ pi 2))
(* pi 2.0))
TH)
TH (rtd AA)
AA1)
(if (or (> (car P1) (car P2))
(= (rtd AA) 270))
(command "rotate" "last" "" P3 180.0)
);if
(command "text" "m"
(polar P3
(rem (+ AA (* pi 1.5))
(* pi 2.0))
TH)
TH (rtd AA)
BNG)
(= BNG "south"))
);if
(command "line" P1 P2 "")
(setq P1 P2)
(princ);end program cleanly
);defun
HOW CAN I MAKE THE OUTPUT LIKE THIS IMAGE
Okay I'll bite..... See below. Do you need the colors to match as well?
;;; * distance and bearing label for lines (graphscr) (prompt "\nloading. . .") ;;; convert radians to degrees (defun rtd (R) (/ (* R 180.0) pi)) (defun C:brg2 () ;;; input for line notations (setq P1 (getpoint "\nFirst point: ")) (while (setq P2 (getpoint p1 "\nSecond point: ")) (setq T1 "Text Height: <default = " T2 ">: " T3 (getvar "textsize") );setq (terpri) (setq TH (getreal (strcat T1 (rtos T3 2 2) T2))) (if (= TH nil) (setq TH t3)) ;;; determine if bearings are true north, south, east, or west (defun nsew () (if (and (= (car P1) (car P2)) (< (cadr P1) (cadr P2))) (setq BNG "north") );if (if (and (< (car P1) (car P2)) (= (cadr P1) (cadr P2))) (setq BNG "east") );if (if (and (= (car P1) (car P2)) (> (cadr P1) (cadr P2))) (setq BNG "south") );if (if (and (> (car P1) (car P2)) (= (cadr P1) (cadr P2))) (setq BNG "west") );if );defun ;;; place text on line (setq AA (angle P1 P2) DS (distance P1 P2) P3 (polar P1 AA (/ DS 2.0)) AA1 (strcat (rtos (/ DS 12.0) 2 2) "'") );setq ;calculate bearing from coordinates and format for printing (defun bearing () (setq O (- (car P2) (car P1)) T (- (cadr P2) (cadr P1)) AZMTH (/ (* (atan (/ O T)) 180.0) pi) A (abs AZMTH) D (fix A) M (* 60 (- A D)) S (* 60 (- M (fix M))) M (fix M) );setq (if (= "60" (rtos s 2 0)) (setq M (+ 1 m))) (if (= "60" (rtos s 2 0)) (setq S 0)) (if (= "60" (rtos m 2 0)) (setq D (+ 1 d))) (if (= "60" (rtos m 2 0)) (setq M 0)) (if (< (cadr P2) (cadr P1)) (setq G "S") (setq G "N")) (if (< (car P1) (car P2)) (setq H "W") (setq H "W")) (setq BNG (strcat G "" (if (< D 10) (strcat "0" (rtos D 2 0)) (rtos D 2 0)) "%%d" (if (< M 10) (strcat "0" (rtos M 2 0)) (rtos M 2 0)) "'" (if (< S 10) (strcat "0" (rtos S 2 0)) (rtos S 2 0)) "''" "" H)) );setq ;;; bearing and distance on line (if (or (= 0 (- (car P1) (car P2))) (= 0 (- (cadr P1) (cadr P2)))) (nsew) (bearing)) (command "text" "m" (polar P3 (rem (+ AA (* pi 1.5)) (* pi 2.0)) TH) TH (rtd AA) (strcat BNG " " AA1)) (if (or (> (car P1) (car P2)) (= BNG "south")) (command "rotate" "last" "" P3 180.0) );if (command "line" P1 P2 "") (setq P1 P2) ) (princ);end program cleanly );defun
Opps... Try this one...
;;; * distance and bearing label for lines (graphscr) (prompt "\nloading. . . ") ;;; convert radians to degrees (defun rtd (R) (/ (* R 180.0) pi)) (defun C:brg2 () ;;; input for line notations (setq P1 (getpoint "\nFirst point: ")) (while (setq P2 (getpoint p1 "\nSecond point: ")) (setq T1 "Text Height: <default = " T2 ">: " T3 (getvar "textsize") );setq (terpri) (setq TH (getreal (strcat T1 (rtos T3 2 2) T2))) (if (= TH nil) (setq TH t3)) ;;; determine if bearings are true north, south, east, or west (defun nsew () (if (and (= (car P1) (car P2)) (< (cadr P1) (cadr P2))) (setq BNG "north") );if (if (and (< (car P1) (car P2)) (= (cadr P1) (cadr P2))) (setq BNG "east") );if (if (and (= (car P1) (car P2)) (> (cadr P1) (cadr P2))) (setq BNG "south") );if (if (and (> (car P1) (car P2)) (= (cadr P1) (cadr P2))) (setq BNG "west") );if );defun ;;; place text on line (setq AA (angle P1 P2) DS (distance P1 P2) P3 (polar P1 AA (/ DS 2.0)) AA1 (strcat (rtos (/ DS 12.0) 2 2) "'") );setq ;calculate bearing from coordinates and format for printing (defun bearing () (setq O (- (car P2) (car P1)) T (- (cadr P2) (cadr P1)) AZMTH (/ (* (atan (/ O T)) 180.0) pi) A (abs AZMTH) D (fix A) M (* 60 (- A D)) S (* 60 (- M (fix M))) M (fix M) );setq (if (= "60" (rtos s 2 0)) (setq M (+ 1 m))) (if (= "60" (rtos s 2 0)) (setq S 0)) (if (= "60" (rtos m 2 0)) (setq D (+ 1 d))) (if (= "60" (rtos m 2 0)) (setq M 0)) (if (< (cadr P2) (cadr P1)) (setq G "S") (setq G "N")) (if (< (car P1) (car P2)) (setq H "E") (setq H "W")) (setq BNG (strcat G "" (if (< D 10) (strcat "0" (rtos D 2 0)) (rtos D 2 0)) "%%d" (if (< M 10) (strcat "0" (rtos M 2 0)) (rtos M 2 0)) "'" (if (< S 10) (strcat "0" (rtos S 2 0)) (rtos S 2 0)) "''" "" H)) );setq ;;; bearing and distance on line (if (or (= 0 (- (car P1) (car P2))) (= 0 (- (cadr P1) (cadr P2)))) (nsew) (bearing)) (command "text" "m" (polar P3 (rem (+ AA (* pi 1.5)) (* pi 2.0)) TH) TH (rtd AA) (strcat BNG " " AA1)) (if (or (> (car P1) (car P2)) (= BNG "south")) (command "rotate" "last" "" P3 180.0) );if (command "line" P1 P2 "") (setq P1 P2) ) (princ);end program cleanly );defun
This should match your original post....
;;; Distance and bearing label for lines ;;; (graphscr) (prompt "\nloading. . . ") ;;; convert radians to degrees (defun rtd (R) (/ (* R 180.0) pi)) (defun C:brg2 () ;;; input for line notations (setq cc (getvar 'cecolor)) (if (setq P1 (getpoint "\nFirst point: ")) (while (and (setq P2 (getpoint p1 "\nSecond point: ")) );and (if (not (setq T1 (getreal (strcat "\nText Height: <" (rtos (getvar 'textsize) 2 2) "> ")))) (setq T1 (getvar 'textsize)) ) ;;; determine if bearings are true north, south, east, or west (defun nsew () (if (and (= (car P1) (car P2)) (< (cadr P1) (cadr P2))) (setq BNG "north") );if (if (and (< (car P1) (car P2)) (= (cadr P1) (cadr P2))) (setq BNG "east") );if (if (and (= (car P1) (car P2)) (> (cadr P1) (cadr P2))) (setq BNG "south") );if (if (and (> (car P1) (car P2)) (= (cadr P1) (cadr P2))) (setq BNG "west") );if );defun ;;; place text on line (setq AA (angle P1 P2) DS (distance P1 P2) P3 (polar P1 AA (/ DS 2.0)) AA1 (strcat (rtos (/ DS 12.0) 2 2) " M.") );setq ;;; calculate bearing from coordinates and format for printing (defun bearing () (setq O (- (car P2) (car P1)) T (- (cadr P2) (cadr P1)) AZMTH (/ (* (atan (/ O T)) 180.0) pi) A (abs AZMTH) D (fix A) M (* 60 (- A D)) S (* 60 (- M (fix M))) M (fix M) );setq (if (= "60" (rtos s 2 0)) (setq M (+ 1 m))) (if (= "60" (rtos s 2 0)) (setq S 0)) (if (= "60" (rtos m 2 0)) (setq D (+ 1 d))) (if (= "60" (rtos m 2 0)) (setq M 0)) (if (< (cadr P2) (cadr P1)) (setq G "S") (setq G "N")) (if (< (car P1) (car P2)) (setq H "E") (setq H "W")) (setq BNG (strcat G "" (if (< D 10) (strcat "0" (rtos D 2 0)) (rtos D 2 0)) "%%d" (if (< M 10) (strcat "0" (rtos M 2 0)) (rtos M 2 0)) "'" (if (< S 10) (strcat "0" (rtos S 2 0)) (rtos S 2 0)) "''" "" H)) );setq ;;; bearing and distance on line (if (or (= 0 (- (car P1) (car P2))) (= 0 (- (cadr P1) (cadr P2)))) (nsew) (bearing)) (setvar 'cecolor "3") (command "_.text" "m" "_none" (polar P3 (rem (+ AA (* pi 1.5)) (* pi 2.0)) T1) T1 (rtd AA) (strcat BNG " " AA1) ) (if (or (> (car P1) (car P2)) (= BNG "south")) (command "_.rotate" "last" "" P3 180) );if (setvar 'cecolor "5") (command "_.line" "_none" P1 "_none" P2 "") (setq P1 P2) ) );if (setvar 'cecolor cc) (princ) );defun
This should do the trick....
;;; Distance and bearing label for lines ;;; (graphscr) (prompt "\nloading. . . ") ;;; convert radians to degrees (defun rtd (R) (/ (* R 180.0) pi)) (defun C:brg2 () ;;; input for line notations (setq cc (getvar 'cecolor) ts (getvar 'textsize) ) (if (setq P1 (getpoint "\nFirst point: ")) (while (and (setq P2 (getpoint p1 "\nSecond point: ")) );and (if (not (setq T1 (getreal (strcat "\nText Height: <" (rtos (getvar 'textsize) 2 2) "> ")))) (setq T1 (getvar 'textsize)) ) ;;; determine if bearings are true north, south, east, or west (defun nsew () (if (and (= (car P1) (car P2)) (< (cadr P1) (cadr P2))) (setq BNG "north") );if (if (and (< (car P1) (car P2)) (= (cadr P1) (cadr P2))) (setq BNG "east") );if (if (and (= (car P1) (car P2)) (> (cadr P1) (cadr P2))) (setq BNG "south") );if (if (and (> (car P1) (car P2)) (= (cadr P1) (cadr P2))) (setq BNG "west") );if );defun ;;; place text on line (setq AA (angle P1 P2) DS (distance P1 P2) P3 (polar P1 AA (/ DS 2.0)) AA1 (strcat (rtos (/ DS 12.0) 2 2) " M.") );setq ;;; calculate bearing from coordinates and format for printing (defun bearing () (setq O (- (car P2) (car P1)) T (- (cadr P2) (cadr P1)) AZMTH (/ (* (atan (/ O T)) 180.0) pi) A (abs AZMTH) D (fix A) M (* 60 (- A D)) S (* 60 (- M (fix M))) M (fix M) );setq (if (= "60" (rtos s 2 0)) (setq M (+ 1 m))) (if (= "60" (rtos s 2 0)) (setq S 0)) (if (= "60" (rtos m 2 0)) (setq D (+ 1 d))) (if (= "60" (rtos m 2 0)) (setq M 0)) (if (< (cadr P2) (cadr P1)) (setq G "S") (setq G "N")) (if (< (car P1) (car P2)) (setq H "E") (setq H "W")) (setq BNG (strcat G "" (if (< D 10) (strcat "0" (rtos D 2 0)) (rtos D 2 0)) "%%d" (if (< M 10) (strcat "0" (rtos M 2 0)) (rtos M 2 0)) "'" (if (< S 10) (strcat "0" (rtos S 2 0)) (rtos S 2 0)) "''" "" H)) );setq ;;; bearing and distance on line (if (or (= 0 (- (car P1) (car P2))) (= 0 (- (cadr P1) (cadr P2)))) (nsew) (bearing)) (setq TPT (polar P3 (rem (+ AA (* pi 1.5)) (* pi 2.0)) T1)) (setvar 'cecolor "3") (command "_.text" "m" "_none" TPT T1 (rtd AA) (strcat BNG " " AA1)) (if (or (> (car P1) (car P2)) (= BNG "south")) (command "_.rotate" "last" "" "_none" TPT 180) );if (setvar 'cecolor "5") (command "_.line" "_none" P1 "_none" P2 "") (setq P1 P2) );while );if (setvar 'cecolor cc) (setvar 'textsize ts) (princ) );defun
