worked good after a little practice. Just got done designing and fabing a trans sq to rnd dbl offset which your progam does...but the plane of discharge end (round) was not parallel with the inlet. Maybe when you are bored one day you can add a feture to vary the plane of the discharge end reletive the the inlet (on both axis). I used the tried and true cardboard model method 🙂
thanks for making this available.
The command line works great in 2015 Elec. I keep getting a diamond shape where I need a round connection. Either I am inputting the wrong answers or my video card is still out of it. The 3D factor works great.
