Simple Text Parsing Using SSGET and the READ Function
7 REPLIES 7
Message 1 of 8
msisler
842 Views, 7 Replies
I'm new to VLISP and I've been seeking the online references for this task it's time to ask others.
I have a bunch of street addresses on the screen that are all TEXT entities, e.g. 4621 N KERBY AVE.  I simply want to parse the text to the first space character so it only has the number, in this case it would leave 4621 only.
Here's the basic start so I can add on conditionals or whatever it is I would need.  Can anyone suggest what direction I should take this in?
(defun c:addresses (/ addr)
  (setq addr (ssget '((0 . "TEXT"))))
  (read addr)
Thank You!
You CAD!
Tags (1)
7 REPLIES 7
Message 2 of 8
Shneuph
in reply to: msisler
This will print out the numbers to the commandline... IDK what your final goal is to do w/ the numbers.. Do you want to modify the text objects to only have the number?  Regardless, here is 1 demo:
(defun c:addresses (/ addr n str)
  (setq n (- (sslength addr) 1))
  (while (> n -1)
    (setq str (cdr (assoc 1 (entget (ssname addr n)))))
    (princ (substr str 1 (vl-string-search " " str)))
    (terpri)
    (setq n (1- n))
    );while
  (princ)
  );defun
---sig---------------------------------------
'(83 104 110 101 117 112 104 64 71 109 97 105 108 46 99 111 109)
Message 3 of 8
msisler
in reply to: Shneuph
Yes, I want to modify the text objects so they only have the number.
And thank you for the clarification; the READ command is the wrong choice becuase the return can only be output to the command line.  Got it!
You CAD!
Message 4 of 8
Jason.Piercey
Something like the following:
(defun c:addresses (/ ss i object string result)
  (if (setq ss (ssget '((0 . "TEXT"))))
    (progn
      (setq i 0)
      (repeat (sslength ss)
	(setq object (vlax-ename->vla-object (ssname ss i)))
	(setq string (vla-get-textstring object))
	(setq result (car (parse string (chr 32))))
	(if (numberp (read result))
	  (vla-put-textstring object result)
	(setq i (1+ i))
  (princ)
; creates multiple strings from a single string
; [s] - string, string to breakdown
; [d] - string, separator
; return: list of strings
(defun parse (s d / i l tmp rtn)
 (cond
  ((/= "" d)
   (setq l (strlen d))
   (while (setq i (vl-string-search d s))
    (setq tmp (substr s 1 i))
    (setq rtn (cons tmp rtn))
    (setq s (substr s (1+ (+ l (strlen tmp))) (strlen s)))
   (vl-remove "" (reverse (cons s rtn)))
  (t s)
Message 5 of 8
msisler
in reply to: Jason.Piercey
Almost!  It didn't seem to parse to the first space, however, because the address
4635-4637 N CONGRESS AVE
remained the same.
You CAD!
Message 6 of 8
Jason.Piercey
Without using READ and removing verification the first characters are numbers:
    (progn
      (setq i 0)
	(setq i (1+ i))
  (princ)
 (cond
  ((/= "" d)
   (setq l (strlen d))
  (t s)
Message 7 of 8
Jason.Piercey
remained the same.
Are you saying in this case you only want 4635 or 4635-4637 ?
Message 8 of 8
msisler
Thank you!
You CAD!
”Boost
