Visual LISP, AutoLISP and General Customization
Setting Out LISP query
3 REPLIES 3
jhockley
390 Views, 3 Replies
I have a LISP routine (below) that shows the bottom co-ords 19.754, -3.663
I want it to show like the top one - with a carriage return in it.
19.754
-3.663
(defun c:lb (/  p x y ptcoord textloc)
  (while
    (setq p (getpoint "\nPick Point: "))
    (setq textloc (getpoint "\nPick Label Location: "))
    (setq x (rtos (car p)))
    (setq y (rtos (cadr p)))
    (setq ptcoord (strcat x ", " y))
    (command "_LEADER" p textloc "" ptcoord "")
What is the simple adjustment to the code that will make this possible?
Also if i wanted to make it like this:
X= 19.754
Y= -3.663
what would i have to do?
3 REPLIES 3
hmsilva
in reply to: jhockley
Perhaps something like this
  (while
    (setq ptcoord (strcat "X= "x "\\PY= " y))
Henrique
jhockley
in reply to: hmsilva
Thanks very much
hmsilva
You're welcome!
Glad I could help
Henrique
”Boost
