Help! How to make a program that use DIMLFAC to change the dimensions according to the selected object scale factor (change selected dimension only)
@Anonymous wrote:Ok, I try to write this lisp. Thanks again.
Good, But did it work for you? Did you make the changes on the code i posted using the snippet at post# 14?
(command "_dimoverride" "DIMLFAC" (* 1.22222 scale1) "" obj "");<--- this
I knew I recognized that code, back then you posted thesame routine, I can see you made a lot of improvements on your routine since then. You included a DCL this time. Good for you.
