Hi
wrote a lisp program to set all dimension var's to specific variables and save it as a dim style
Everything works perfectly except for the variable DIMJOGANG
I'm using
(vla-setvariable *obj*j "DIMGAP" 1.5) ;Gap from dimension line to text
(vla-setvariable*obj*j "DIMJOGANG" 45) ;Radius dimension jog angle
(vla-setvariable*obj*j "DIMJUST" 0) ;Justification of text on dimension line
but whatever value I put in for DIMJOGANG gives me
; error: Automation Error. Error setting system variable
tried it on acad2009 and 2010
anybody ?? it's driving me crazy
Thx in advance
Patrick
I'm guessing here [I don't have that System Variable]....
Could it be that the value needs to be in radians rather than degrees, and that it won't accept a value larger than 2 pi? See whether setting it to (/ pi 4) works.
Or, could it be that you have a space between '...variable' and '*obj*j' in the line above, but not in that line?
Enter this at the command prompt:
(type (getvar "DIMJOGANG"))
If it reads "STR" then change to say "45"
If it reads "REAL" then change to say 45.0
If it reads "INT" then, as Kent says, it might require radians.
When all else fails, set it manually and reenter the type query.
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
Hi
thanks for the infor
sorry, the correct line should read (vla-setvariable *doc* "DIMJOGANG" 45.0) ;Radius dimension jog angle
I already tried the 45.0 and the statement (type ... does return a REAL
Command: (type (getvar "DIMJOGANG"))
REAL
I reaaly don't understand it anymore, every other vla-setvariable works (BUG ??? )
Thanks for following up
Patrick
