Hello, Is the common string in the block a text object in the block definition or is it an attribute value? Depending on what it is, I can suggest two different solutions: 1. If the common string is a block attribute value, then you can use a function called (SS_SSGetBlkAtt...) to make a selection set of blocks that have an attribute which matches with a given value. This library function (and any other library function that it requires) is available for free download from our Tech Center (see free downloads URL below) under the Blocks library. You can use this to build your selection set meeting your criteria. 2. If the common text string is part of the block definition, take a look at our GeoTools program (see URL below for a fully functional download). The GT_SRCHBLK4TXT command identifies blocks which have a particular text string in its definition. If you need any tweaking, email me for more info. Regards Rakesh coachball8 wrote: > I have a block comprised of a set of notes that exists in a number of drawings. The problem is that it has been named differently in each drawing. Is there a way I can identify it by a common text string within the block? TIA -- AutoCAD customization for Engineering/Mapping/GIS Get GeoTools @ http://www.4d-technologies.com/geotools Build MyGeoTools @ http://www.4d-technologies.com/geotools/my_geotools.htm FREE downloads : http://www.4d-technologies.com/techcenter
