Setenv, getenv How to DELENV??
2 REPLIES 2
SAPER59
1301 Views, 2 Replies
I need to erase a variable seted to the environment with SETENV, but not seting it to a value like "".
I need that when it is reading with GETENV, return a NIL value like when it wasn't exist after the first seting
Thanks in advance
2 REPLIES 2
patrick_35
in reply to: SAPER59
Hi
For example
(defun delenv(env / cle)
  (setq cle (strcat "HKEY_CURRENT_USER\\" (vlax-product-key) "\\FixedProfile\\General"))
  (if (vl-registry-read cle env)
    (vl-registry-delete cle env)
scot-65
If not mistaken, SETENV and GETENV accesses the registry keys established by the software.
By deleting these keys you are asking for trouble.
If you established keys using VL-REGISTRY-WRITE, and you SETVAR/SETENV using your
VL-REGISTRY-READ, deleting these keys will only corrupt your program, and not the software.
Be careful.
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
”Boost
