Member
thierry.huisman
Message 1 of 3 (198 Views)
Set variable depending on location folder (find directory)
198 Views, 2 Replies
09-20-2012 07:54 AM
We have user folders on severall servers, now I want the user menu's to be stored on the network so their home folder depends on what server it's located on. I tried using the vl-file-directory-p command but it doesn't seem to work.
Even worse, as soon as the userfolder is found I want to let the script check for a file called user.cuix in the Acad folder and if it doesn't excists copy it from another location to that folder (if possible).
This is what I got so far:
(setq UserName (getvar "loginname"))
(setq RootZW "\\\\users\\zw\\")
(setq RootVL "\\\\users\\vl\\")
(setq Company "\\\\CADConf\\ACAD13\\")
(if (vl-file-directory-p (strcat RootZW UserName))
 (progn
  (setq AcadMap (strcat RootZW UserName "\\acad\\")
(if (vl-file-directory-p (strcat RootVL UserName))
 (progn
  (setq AcadMap (strcat RootVL UserName "\\acad\\")
(setenv "MenuFile" (strcat AcadMap "user.cuix"))
Next to this we have 4 other options as well, but to keep it short I left it at the first 2.
Valued Mentor
martti.halminen
Message 2 of 3 (170 Views)
Re: Set variable depending on location folder (find directory)
09-21-2012 12:00 AM in reply to: thierry.huisman
Are you quite sure about your paths?
Seems to me you have RootVL and RootZW both pointing to the same server.
Member
thierry.huisman
Message 3 of 3 (167 Views)
09-21-2012 12:34 AM in reply to: martti.halminen
Difference is in the folder (one is ZW other is VL). We also have an entirely different server as well
