Visual LISP, AutoLISP and General Customization
Set text height
1 REPLY 1
edeyo10
258 Views, 1 Reply
Set text height
Using the tool palette can you without lisp set the text height per dimscale? This is for a LT install so obviously I can't use lisp. Can I pull the variable for dimscale in a macro?
Erik
1 REPLY 1
in reply to: edeyo10
I got it.
I needed to use DIESEL, here's the code if someone needs it.
^C^CTEXTSIZE;$M=$(*,$(getvar,dimscale),0.12);_mtext
Erik
wrote in message news:5692309@discussion.autodesk.com...
Erik
”Boost
