Visual LISP, AutoLISP and General Customization
Set MLeader to Existing MLeader Style via LISP
15 REPLIES 15
Message 1 of 16
2837 Views, 15 Replies
I am trying to create a lisp routine that sets all existing MLEADERs to a certain pre-set MLEADERSTYLE, the equivalent of doing a Quick Select for Mleaders, and setting the style under the properties window.
I was able to write a similar routine that selects all dimensions and sets them to a certain DIMSTYLE, using entmod and DXF code 3 for dimstyle.  So far, I have not been able to find a group code for MLEADERSTYLE
 Any help would be greatly appreciated!
(defun C:dimstylechange (/ ENTITIES NO_OF_ENTITIES SSPOSITION ENTITY_NAME
OLD_ENTLIST NEW_STYLE NEW_ENTLIST)
(setvar "CMDECHO" 0)
(setq ENTITIES (ssget "X" '((0 . "DIMENSION"))))
(setq NO_OF_ENTITIES (sslength ENTITIES))
(setq SSPOSITION 0)
(repeat NO_OF_ENTITIES
;***CHANGE STYLE***
(setq ENTITY_NAME (ssname ENTITIES SSPOSITION))
(setq OLD_ENTLIST (entget ENTITY_NAME))
(setq OLD_STYLE (assoc 3 OLD_ENTLIST))
(setq NEW_STYLE (cons 3 "BCR 11x17"))
(setq NEW_ENTLIST (subst NEW_STYLE OLD_STYLE OLD_ENTLIST))
(entmod NEW_ENTLIST)
;***CHANGE LAYER***
(setq OLD_STYLE (assoc 8 OLD_ENTLIST))
(setq NEW_STYLE (cons 8 "DIM"))
(setq SSPOSITION (1+ SSPOSITION))
(command ".CHPROP" ENTITIES "" "C" "BYLAYER" "LT" "BYLAYER" "")
(princ (strcat "\n..." (rtos NO_OF_ENTITIES 2 0) " Dimension(s) changed..."))
(setvar "CMDECHO" 1)
(princ)
15 REPLIES 15
Message 2 of 16
Kent1Cooper
@Anonymous wrote:
....  So far, I have not been able to find a group code for MLEADERSTYLE
I don't have MLeaders [too old a version of AutoCAD], but I wonder whether that might be available with a little less work as a VLA Property.  Try drawing an MLeader [so it's the last thing in the drawing], then doing:
(vlax-dump-object (vlax-ename->vla-object (entlast)))
and see whether any of the listed Properties contains the current style.  [For Text and Mtext and Dimensions, the Property is called "StyleName", and it could very well be the same for MLeaders.]  If it does, you can use a (vla-put...) operation on a vla-object conversion of each MLeader found, instead of the whole (entget)/(subst)/(entmod) procedure.
Kent Cooper, AIA
Message 3 of 16
phanaem
How often do you need to do that? Maybe a Quick Select and change style in properties dialog is enough.
But if you have some reasons to use lisp, try this:
(defun C:TEST ( / *error* acDoc l new e ss)
  (setq acDoc (vla-get-activeDocument (vlax-get-acad-object)))
  (vla-StartUndoMark acDoc)
  (defun *error* (msg)
    (princ msg)
    (vla-EndUndoMark acDoc)
  (if
    (ssget "_X" '((0 . "MULTILEADER")))
     (progn
       (princ "\n\n\n****Mleader Styles****\n\n")
       (setq l (mapcar
                 (function
                   (lambda (s)
                     (princ (strcat "   " (cdr s) "\n"))
                     (cdr s)
                 (vl-remove-if
                   '(lambda (x) (/= (car x) 3))
                   (dictsearch (namedobjdict) "ACAD_MLEADERSTYLE")
       (textscr)
       (if
         (member (setq new (getstring T "\nEnter new style name: ")) l)
          (progn
            (vlax-for e (setq ss (vla-get-ActiveSelectionSet acDoc))
              (vla-put-StyleName e new)
            (vla-delete ss)
          (princ "\nStayle name not found.")
       (graphscr)
  (princ)
Message 4 of 16
in reply to: phanaem
Hello, about your lisp is it possible to apply a Mleader Styles in accordance with the dimstyle?
Exemple:
-dimstyle 01_Dim1-1 have the mleader Styles 01_Tender1-1
-dimstyle 01_Dim1-2 have the mleader Styles 01_Tender1-2
Message 5 of 16
phanaem
I'm not sure I understood your request. Can you clarify your goal a little bit more?
Message 6 of 16
When a purge my drawing I lose the mleader style of my annotation and only when I restore them I can add or remove leaders!
For exemple find attached a drawing with 3 different Mleaderstyle.
Thanks for your help
Message 7 of 16
phanaem
It is the first time I see a mleader without a style associated. How do you get this kind of mleader? Maybe imported from other software? Anyway, based only on presence of a dimstyle, it is hard to create a association between a mleader and a style name. I guess you want to create a mleader style for each of the orphan (that is, without style) mleader object, but I don't see any clear way to associate a particular object to a particular style name.
Message 8 of 16
Hi, I lose the mleader style by purge, to have again the mleader style I reinsert the template on which I have all mleader style and all dimstyle
Message 9 of 16
ahmed.abdelmotey
no error trapping but try this - not tested
(defun c:CMS()
(vla-com-load)
(setq
ss (ssget "_X" '((0 . "MULTILEADER")))
i 0
(repeat (sslength ss)
(setq obj (vlax-ename->vla-object (ssname ss i)))
(vla-put-StyleName obj "Your Style")
(setq i (1+ i))
(princ)
you can also change "Your Style"  to the following code
(vl-string-subst "Tender" "Dim" (vla-get-stylename obj))
This will change the dimention style from *Dim* to *tender*
Ahmed Abd-Elmotey
Landscape Architect & beginner lisp programmer
Message 10 of 16
in reply to: ahmed.abdelmotey
Good morning,
I tested your lisp but a get an error message: error: no function definition: VLA-COM-LOAD
I modifed (vla-com-load) to (vl-load-com) but i get an oder error message: ; error: Automation Error. Null object ID
Even if I will not have a positive result I thank you for your help
Message 11 of 16
ahmed.abdelmotey
sorry for the first strange function (vla-com-load) i usually don't use it.
I didn't use error trapping .. this error means that you don't have a style that matches the pattern you said about
eg.
for mlstyle called 01_Dim1-1 >> 01_Tender1-1 is not available in the drawing
Ahmed Abd-Elmotey
Message 12 of 16
All needed style are on the drawing
What I need exactly is to assign to the mleader with layer Dim1-1 the mleader style 01_Tender1-1
Mleader with layer Dim1-1 = mleaderstyle 01_Tender1-1
Mleader with layer Dim1-2 = mleaderstyle 02_Tender1-2
Mleader with layer Dim1-3 = mleaderstyle 03_Tender1-3
Message 13 of 16
hmsilva
HI francinez,
Untested...
(vl-load-com)
(defun c:demo (/ i lay mlstyles obj ss)
    (if (setq ss (ssget "_X" '((0 . "MULTILEADER"))))
        (progn
            (or adoc (setq adoc (vla-get-activedocument (vlax-get-acad-object))))
            (vlax-for ml (vla-item (vla-get-dictionaries adoc) "ACAD_MLEADERSTYLE")
                (setq mlstyles (cons (vla-get-name ml) mlstyles))
            (repeat (setq i (sslength ss))
                (setq obj (vlax-ename->vla-object (ssname ss (setq i (1- i))))
                      lay (vla-get-layer obj)
                (cond ((and (vl-position "01__Tender 1-1" mlstyles)
                            (= lay "Dim 1-1")
                            (vlax-write-enabled-p obj)
                       (vla-put-stylename obj "01__Tender 1-1")
                      ((and (vl-position "01__Tender 1-2" mlstyles)
                            (= lay "Dim 1-2")
                       (vla-put-stylename obj "01__Tender 1-2")
                      ((and (vl-position "01__Tender 1-3" mlstyles)
                            (= lay "Dim 1-3")
                       (vla-put-stylename obj "01__Tender 1-3")
    (princ)
Hope this helps,
Henrique
Message 14 of 16
in reply to: hmsilva
Perfect I have testet it and it works, only little change with the exact name of mleader style!
Spoiler
Smiley Happy
Message 15 of 16
hmsilva
Glad I could help! 🙂
Henrique
Message 16 of 16
ahmed.abdelmotey
am sorry i was searching for a mleader style called Dim 1-3 ! glad that hmsilva solution worked for you.
Ahmed Abd-Elmotey
”Boost
