Hi guys
I want to set distance 1.4 gap between text in x-axis and y- axis ... i have attach one sample for make distance in y axis move ..
Other details
Text height 2.72
and one more if it possible
In lisp ask for how much distance want to move... bcz sometimes i hav to set 1.4 or 1.7 gap ..for tat only.... thank you
Solved by pbejse. Go to Solution.
So if the text not 2.72 height then ignore them? or some other gap distance?
NO...text height always 2.72 only but distance only very ( 1.4 or 1.7 ) ....
@377-83869076 wrote:
NO need to prompt for other value ..... ! set 1.4 is enough
On a side note. Please refrain from using ( ! ) and CAPITAL LETTERS as if you are ordering people around as oppose to requesting help or assistance.
I have a routine to do the job but it is not ready for share with public. You are welcome to send me the dwg in private message and I can format all the texts for you.
Precondition of the drawing as below:
;;; Before running it, all texts must have been formated as following: ;;; 1. The rule is based on different text height. ;;; 2. All Text justification should be "Left" ;;; Use "TJUST" in Express ->Text ->Jusify Text to batch change the text justification but keep the original position. ;;; Change them back to preferred justification after running the program. ;;; 3. All Mtext justification should be "BL". (Ctrl + 1) ;;; 4. Do not put texts in different height in the same row
Unfortunately, it is not able to adjust spaces bewteen words in the same row.
It can only adjust spaces between different rows, as shown below:
As I said before, this routine is not for share for time being. You can send me the dwg file and I can fix the text spacing for you.
