Visual LISP, AutoLISP and General Customization
Set distance between text
13 REPLIES 13
Message 1 of 14
377-83869076
728 Views, 13 Replies
Hi guys
 I want to set distance 1.4 gap between text in x-axis and y- axis ... i have attach one sample for make distance in y axis move ..
Other details
Text height 2.72
and one more if it possible
In lisp ask for how much distance want to move... bcz sometimes i hav to set 1.4 or 1.7 gap ..for tat only.... thank you
13 REPLIES 13
Message 2 of 14
pbejse
in reply to: 377-83869076
So if the text not 2.72 height then ignore them? or some other gap distance?
Message 3 of 14
377-83869076
in reply to: pbejse
NO...text height always 2.72 only but distance only very ( 1.4 or 1.7 ) ....
Message 4 of 14
pbejse
Exclusively 1.4 or 1.7 only? no prompt for other value?
Message 5 of 14
377-83869076
in reply to: pbejse
NO need to prompt for other value ..... ! set 1.4 is enough
Message 6 of 14
pbejse
On a side note. Please refrain from using ( ! ) and CAPITAL LETTERS as if you are ordering people around as oppose to requesting help or assistance.
Message 7 of 14
377-83869076
in reply to: pbejse
Not like tat friend ... i just asking help only i never oppose anybody bcz u guys are helping lots for my work ... and capital letter and symbol all are using just for differentiate bcz am not fluency in English.... 🙂
Message 8 of 14
3wood
I have a routine to do the job but it is not ready for share with public. You are welcome to send me the dwg in private message and I can format all the texts for you.
Precondition of the drawing as below:
;;; Before running it, all texts must have been formated as following:
;;; 1. The rule is based on different text height.
;;; 2. All Text justification should be "Left"
;;;    Use "TJUST" in Express ->Text ->Jusify Text to batch change the text justification but keep the original position.
;;;    Change them back to preferred justification after running the program.
;;; 3. All Mtext justification should be "BL". (Ctrl + 1)
;;; 4. Do not put texts in different height in the same row
Message 9 of 14
377-83869076
in reply to: 3wood
Thanks wood i ll send file .....
Message 10 of 14
377-83869076
in reply to: 3wood
hi
Message 11 of 14
3wood
Unfortunately, it is not able to adjust spaces bewteen words in the same row.
It can only adjust spaces between different rows, as shown below:
Message 12 of 14
377-83869076
in reply to: 3wood
ok wood send the lisp i ll check ... Tat also help me in some other way but thank so much for ur contribution frd....:)
Message 13 of 14
3wood
As I said before, this routine is not for share for time being. You can send me the dwg file and I can fix the text spacing for you.
Message 14 of 14
377-83869076
Wood no thanks bcz I ll do the same change for different files min 20files per day for that only I asking lisp to minimize the time . It's ok thanks once again wood for ur help :-/:-)
”Boost
