Visual LISP, AutoLISP and General Customization
0 Kudos
Post 1 of 4
set basepoint during insertion of blocks with AutoLISP
345 Views, 3 Replies
01-14-2013 08:31 AM
hello to all
would like to set a base point during insertion of one block.
When not insert by AutoLISP, just type "b" to be able to change the base point.
But when I'm using an AutoLISP that inserts a block, it does not work, it interrupts the sequence of routine.
Anyone have a tip that can help me improve routine?
Lisp:
(defun c:carrobox()
(setq #clayer (getvar "clayer"))
(if (= unidades nil)(setq unidades "cm"))
(if(= unidades "cm")(setq scalefactor 1.0)(setq scalefactor 0.01))
(if (= numberboxcar nil)(setq numberboxcar 1))
(if (= passoboxcar nil)(setq passoboxcar 1))
(setq frase (strcat "\nBloco de box [Inserir,Numero = " (itoa numberboxcar)",Soma = +"(itoa passoboxcar)",-----, Un = " unidades "]<Inserir>"))
(initget "I N S U" 0)
(setq op (getkword  frase))
(cond
((= op "U")(if(= unidades "cm")(setq unidades "metros")(setq unidades "cm"))(C:carrobox))
((= op "N")(setq numberboxcar(getint "\nNúmero do box atual: "))(C:carrobox))
((= op "S")(setq passoboxcar(getint "\nIncremento a cada box: "))(C:carrobox))
(or(= op "I")(= op nil))
(inserirboxdecarro)
(setvar "clayer" #clayer)
(defun inserirboxdecarro()
(if (not (tblsearch "layer" "box de estacionamentos"))(command "._-layer" "m" "box de estacionamentos" "c" "13" "" ""))(progn(command "._-layer" "on" "box de estacionamentos" "thaw" "box de estacionamentos""")(setvar "clayer" "box de estacionamentos"))
(command "._INSERT" "box de carro.dwg" "scale" scalefactor PAUSE pause numberboxcar)
(setq numberboxcar (+ numberboxcar passoboxcar))
(inserirboxdecarro)
Thanks In Advance
*Expert Elite*
306 Kudos
Post 2 of 4
Re: set basepoint during insertion of blocks with AutoLISP
01-17-2013 12:38 AM in reply to: Gustavo_Bernardi
(defun inserirboxdecarro ()
		(command
	"._-layer"
	"m"
	"c"
	"13"
	) ;_ end of command
		) ;_ end of if
			(progn (command
	 "._-layer"
	 "on"
	 "thaw"
	 ) ;_ end of command
		 ) ;_ end of progn
			(command "._INSERT" "box de carro.dwg" "scale" scalefactor)
			(while (not (zerop (getvar 'cmdactive)))
		(command pause)
		) ;_ end of while
			(vla-put-textstring
		(car
	(vlax-invoke
(vlax-ename->vla-object (entlast))
'GetAttributes
) ;_ end of vlax-invoke
	) ;_ end of car
		numberboxcar
		) ;_ end of vla-put-textstring
 ;_ end of command
			(inserirboxdecarro)
HTH
0 Kudos
Post 3 of 4
01-23-2013 09:12 AM in reply to: pbejse
That helped a lot. Just wanted to know what made it work.
is it?
(command pause)
TKS
*Expert Elite*
306 Kudos
Post 4 of 4
01-25-2013 06:36 AM in reply to: Gustavo_Bernardi
is it?
(command pause)
TKS
Yes Gustavo_Bernardi, it  sets the command in "pause" mode indefinitely until user ends the "insert" command.
Then it assigns the string value  to the attribute.
Cheers
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
