Visual LISP, AutoLISP and General Customization
Selection Set Filter Help Please.
10 REPLIES 10
Message 1 of 11
mid-awe
1100 Views, 10 Replies
Hi all,
I'm putting together some quick function that I can send 2 arguments and get from it the total area of a given hatch on the given layer.
I think everything is in order but I'm having trouble with the selection set filter:
(DEFUN GET-HATCH-AREA (HATCH LAYR / area sset)
  (COND
    ((AND
       (ssget "X" '((0 . "HATCH") (2 . HATCH) (8 . LAYR)))
       (SETQ area 0)
       (VLAX-FOR H (SETQ sset (VLA-GET-ACTIVESELECTIONSET (VLA-GET-ACTIVEDOCUMENT (VLAX-GET-ACAD-OBJECT))))
	 (SETQ area (+ (VLA-GET-AREA h) area))
       (ALERT
	 (STRCAT "\nTotal area = "
		 (IF (OR (= (GETVAR "lunits") 3)
			 (= (GETVAR "lunits") 4)
		   (STRCAT (RTOS area 2) " sq. in. (" (RTOS (/ area 144) 2) " sq. ft.)")
		   (RTOS area)
       (VLA-DELETE sset)
I'm not sure what I've done wrong but given how tired I am, it could be something real dumb. If you see my mistake, please let me know, thank you.
10 REPLIES 10
Message 2 of 11
mid-awe
in reply to: mid-awe
BTW - The error I get when using the function is:
error: bad SSGET list value
Thank you in advance for any help.
Message 3 of 11
hmsilva
mid-awe.
(0 . "HATCH")
(2 . HATCH) ;; hatch patern as a string
(8 . LAYR)));; layer name as a string
Henrique
Message 4 of 11
BlackBox_
In order to supply your variables, in this case two arguments, to your selection set filter, you cannot employ the Quote " ' " symbol, as the precludes evaluation of the quoted list.
Instead try:
(setq ss (ssget "_x"
                (list '(0 . "HATCH")
                      (cons 2 (strcase hatchPattern))
                      (cons 8 (strcase layerName))
                      (cons 410 (getvar 'ctab))
... Here's a complete example, with slight modification to your original code:
(defun Get-Hatch-Area
       (hatchPattern layerName / ss area i msg n fail total)
  (if (and (setq ss (ssget "_x"
           (setq area 0)
           (setq i (sslength ss))
           (setq msg "Total area = ")
    (progn
      (vlax-for x (setq ss
                         (vla-get-activeselectionset
                           (vla-get-activedocument (vlax-get-acad-object))
        (if (not (vl-catch-all-error-p
                   (setq n (vl-catch-all-apply 'vla-get-area (list x)))
          (setq area (append (list n) (list area)))
          (or fail (setq fail T))
      (vla-delete ss)
      (setq total (apply '+ area))
      (if fail
        (setq msg
               (strcat
                 "** Unable to extract area for "
                 (itoa (- i (length area)))
                 " hatch patterns ** \n\n"
                 msg
      (alert
        (strcat msg
                (if (vl-position (getvar 'lunits) '(3 4))
                  (apply 'strcat
                         (list (rtos total 2)
                               " sq. in. ("
                               (rtos (/ total 144) 2)
                               " sq. ft.)"
                  (rtos total)
    (prompt "\n** Nothing selected ** ")
  (princ)
HTH
"How we think determines what we do, and what we do determines what we get."
Message 5 of 11
mid-awe
in reply to: BlackBox_
Thank you very much. You definitely got me thinking differently about this. Although, when I tried your code I recieved the following error.
error: bad argument list tail: 0
Any idea what is going on? (Only thing that I can mention is that I am creating the hatch in the drawing and then calling the sub-function all in the same function. Do I need to do anything for VL to see the hatch object?)
Thank you again.
Message 6 of 11
hmsilva
mid-awe,
ignore my previous post, I have not read the entire code, just saw the "ssget" filter, sorry.
Henrique
Message 7 of 11
BlackBox_
Thank you again.
That is kind of you to say.
I did not experience any errors when running the code on my end, although I did have already generated hatch entities within my drawing... More specifically, I did receive an error when attempting to extract Area property from custom hatch patterns, hence the additional code.
Perhaps someone more knowledgeable than I (not exactly hard to do), will be able to see where I've made a mistake in the code I posted?
In any event, to your issue, perhaps if you posted your working code, I could better help identify the issue my code is generating.
Message 8 of 11
mid-awe
Thank you again Smiley Happy
I found that my suspission was correct, although I don't understand why.
Originally I used a line like:
(vl-cmdf "-HATCH" "P" "GRAVEL" "10" "0" PAUSE "")
to create the hatch. But, for some reason there is no GEOMETRY properties when created that way.
I solved it by breaking the command into parts like:
(vl-cmdf "-HATCH" "P" "GRAVEL" "10" "0" "")
(vl-cmdf "-HATCH" PAUSE "")
And this works with the sub-function and reports no error.
BlackBoxCAD you have been a great help. Smiley Happy Thank you.
Message 9 of 11
BlackBox_
<snip>
Glad you got it sorted.
Again, that is very kind of you to say... I'm always happy to help.
Cheers
Message 10 of 11
pbejse
I seriously did not know that pattern name is case sensitive.
Message 11 of 11
BlackBox_
in reply to: pbejse
That is kind of you to say, pbesje.
To the best of my knowledge, the case sensativity here is a byproduct of the DXF / Selection Set Filter relationship... As the AcDbHatch Object's PatternName Property (read-only) is upper case... Which stems from the upper case name contained within the *.pat file which defines the Hatch Pattern itself.
I am unsure if a given Hatch Pattern definition *must* be upper case or not, given that I have no knowledge of how a .pat file is processed behind the scenes... It's an old, presumably unchanged mechanism that has been a part of AutoCAD since well before my time (just a handful of years ago).
”Boost
