Visual LISP, AutoLISP and General Customization
Selection Set by block name
59 REPLIES 59
Message 1 of 60
spm5
9697 Views, 59 Replies
I am trying to select all blocks of a certian name. I am using the following:
(setq ss1bk (ssget "_X" (list (cons 2 blkname))))
My issue is that this will not select any dynamic or attribute blocks that are not at the default insert state.
Does anyone know how to select all of a block by name including reguardless of current state?
Thanks.
59 REPLIES 59
Message 41 of 60
dortega4226
in reply to: _Tharwat
Tharwat,
Thanks for the reply.
The edit made to your routine does not allow me to get past the select block mode, the routine ends as soon as a block is selected.
David J. Ortega
____________________________________________________________________________________
AutoCAD 2015 | AutoCAD Architecture 2015 | Revit Architecture 2015 | NavisWorks Manage 2015
Autodesk | TheSwamp | CadTutor | AUGI
Message 42 of 60
_Tharwat
in reply to: dortega4226
@dortega4226 wrote:
Tharwat,
Pick the button select and and you prompted to pick a block , pick one then the routine should return a list of layers in the popup list when you being brought back to dialog .
is not that what did happen by the program ?
Message 43 of 60
dortega4226
Here is a quick video of what happens...
http://youtu.be/JY3hR0PF8QM
David J. Ortega
Message 44 of 60
_Tharwat
Maybe the hyperlink affects on the block and the function ssget could not differ between them , so try on another block .
Message 45 of 60
dortega4226
This is what happens when selecting several different blocks...
David J. Ortega
Message 46 of 60
_Tharwat
Because you are using dynamic blocks and I did not consider that , my bad .
Sorry for the confusion so it is too late here now and tomorrow I would modify the program for sure.
Message 47 of 60
dortega4226
Ahh, that is it.  Good catch.Smiley Wink  Thank you very much for your help.
David J. Ortega
Message 48 of 60
_Tharwat
Try this .
I don not understand why you want to list the layers in a list after picking a specific block ?
(defun c:GetBlocks (/ *error* D f id run go sel blocks s lst ss i layer
                    sn vl ss1 en bn go BlockTable
  ;;	Author: Tharwat Al Shoufi	;;
  ;;	GetBlocks Program 		;;
  ;;	Date : 08. August. 2014		;;
  (defun *error* (msg)
    (if (and D (setq D (findfile D)))
      (vl-file-delete D)
    (if (wcmatch (strcase msg) "*BREAK*,*CANCEL*,*EXIT*")
      (princ msg)
      (princ (strcat "\n ** Error : " msg " **"))
  (defun BlockTable (/ i a l nm)
    (while (setq i (tblnext "BLOCK" (not i)))
      (if (not (wcmatch (setq nm (cdr (assoc 2 i))) "`**"))
        (setq l (cons nm l))
    (setq l (acad_strlsort l))
  (if (ssget "_X" '((0 . "INSERT")))
    (setq run t)
    (alert "No blocks found in this drawing !!")
  (if (and run
           (setq D (vl-filename-mktemp nil nil ".dcl"))
           (setq f (open D "w"))
    (progn
      (write-line
        (strcat
          "test : dialog { label = \"Highlight Blocks\"; width = 36;"
          "spacer;" ": boxed_column { label = \"Options\";"
          ": button { label = \"Select >>\"; key = \"sbk\";}" "spacer;"
          ": popup_list { label = \"Block:\"; key = \"bl\"; width = 32;}"
          "spacer;"
          ": popup_list { label = \"Layer:\"; key = \"lay\"; width = 32;}}"
          "spacer;" ": boxed_radio_column { label = \"Selection Way:\";"
          ": radio_button { label = \"Global\"; key = \"g\"; value = \"1\";}"
          ": radio_button { label = \"Window\";key = \"w\";}}" "spacer;"
          ": boxed_row { label = \"Action\"; fixed_width = true; alignment = centered;"
          ": button { label = \"Okay\"; key = \"oki\"; is_default = true; height = 1.75; width = 12;}"
          ": button { label = \"Exit\"; key = \"esc\"; is_cancel = true; height = 1.75; width = 12;}}}"
        f
      (close f)
  (if (or (not D)
          (not (new_dialog "test" (setq id (load_dialog D))))
    (progn (if (> id 0)
             (unload_dialog id)
             (vl-file-delete D)
    (progn
      (setq blocks (BlockTable))
      (start_list "bl")
      (mapcar 'add_list blocks)
      (end_list)
      (if *layers*
        (progn
          (start_list "lay")
          (mapcar 'add_list (acad_strlsort *layers*))
          (end_list)
      (if (and *GetBlockName* (tblsearch "BLOCK" *GetBlockName*))
        (set_tile "bl" (itoa (vl-position *GetBlockName* blocks)))
      (action_tile "sbk" "(setq sel t *layers* nil)(done_dialog)")
      (action_tile
        "oki"
        "(setq lst (mapcar 'get_tile (list \"bl\" \"lay\" \"g\" \"w\"))
                                     bn (nth (atoi (car lst)) blocks)
                                     go t *GetBlockName* nil *layers* nil) (done_dialog)"
      (action_tile "esc" "(setq go nil) (done_dialog)")
      (start_dialog)
      (unload_dialog id)
      (vl-file-delete D)
  (if (and sel
           (princ "\n Pick Block :")
           (setq s (ssget "_+.:S:E" '((0 . "INSERT"))))
           (setq *GetBlockName*
                  (vla-get-effectivename
                    (vlax-ename->vla-object (ssname s 0))
             (setq
               ss (ssget "_X"
                         (list '(0 . "INSERT")
                               (cons 2 (strcat "`*U*," *GetBlockName*))
    (progn
      (repeat (setq i (sslength ss))
        (setq sn (ssname ss (setq i (1- i)))
              vl (vlax-ename->vla-object sn)
        (if (and (eq (vla-get-effectivename vl) *GetBlockName*)
                 (not (member (setq layer
                                     (cdr (assoc 8 (entget sn))
                              *layers*
          (setq *layers* (cons layer *layers*))
      (c:GetBlocks)
  (if (and bn
           go
           (setq ss1 (ssget (if (eq (caddr lst) "1")
                              "_X"
                              "_:L"
;;;                                 (cons 8
;;;                                       (if (eq (cadr lst) "0")
;;;                                         (nth (atoi (cadr lst)) layers)
                                  (cons 2 (strcat "`*U*," bn))
    (progn (repeat (setq i (sslength ss1))
             (if (not (eq (vla-get-effectivename
                              (setq en (ssname ss1 (setq i (1- i))))
                          bn
               (ssdel en ss1)
           (sssetfirst nil ss1)
  (princ)
Message 49 of 60
dortega4226
Tharwat,
This worked, however, the selection should still be based off of the Layer selection.
Example:
  • Select Block named Casework
  • All Casework blocks are selected
  • Layer list is minimized to show only layers used by Casework block(s)
  1. When "-- On Any Layer --" is selected all Casework blocks are selected
  2. When a specific layer is selected, 34" Tall Base Cabinet, then only the Casework blocks on the 34" Tall Base Cabinet layer are selected
You're very close, sorry if I'm not being clear enough for you.  I'm trying to explain as best I can.
David J. Ortega
Message 50 of 60
_Tharwat
@dortega4226 wrote:
Tharwat,
Example:
I think you can not say close or even very close because i have been asking you what to do with the layer list after retrieving them from blocks and you did not answer my question at all and I updated the routine according to what you believe in and not to what I do .
I am sorry , I would end up to this point .
Message 51 of 60
dortega4226
Tharwat,
Thanks for all the help.  I think you're taking offense to something that stemmed from a misunderstand.  I think I've tried to explain it, but I was unsuccessful in explaining and understanding the questions you had asked.  Thank you for your hard work, I won't discount anything you have done for me already.  You have done an excellent job.
Is there anyone else that might be able to decifer what it is I'm trying to achieve and try to give it a go?
David J. Ortega
Message 52 of 60
sbanister
in reply to: pbejse
Hello pbejse
I'm using your selblock lisp & it's good
However I'ne changed a line near the end to display how many block have been selected
Ideally I'd like to put in the name of the blocks to be displayed too, however I'm having trouble with that. It's easy enough with vlide to work out  that the name of the block is stored in variable BN but how do I add it to the attached code?
I've tried (getvar bn) & (entlget bn) without success
I bet it's simple but I don't know how to do it
) (sssetfirst nil selection) (princ (strcat "\n "(itoa (sslength selection))" Blocks [CODE TO DISPLAY NAME OF BLOCK HERE] Selected")) (princ) )
Message 53 of 60
Kent1Cooper
in reply to: sbanister
Since Block names are text strings, you should be able to add the BN variable in with other strings directly in the (strcat) function, e.g.:
(princ (strcat "\n "(itoa (sslength selection))" Blocks " BN " Selected"))
Kent Cooper, AIA
Message 54 of 60
sbanister
in reply to: Kent1Cooper
Ah, thank you Kent
I thought it would be simple
However not that simple !
Message 55 of 60
schlanz
Hey!
I tried this code and if i "select" the block it works great.
But if i try to select a block from the dropdown and "ok" it gives me:  ** Error : bad argument type <NIL> ; expected <CONS> at [nth] **
Also can i change to width of the dialog box to something like 100%? I want to see the full names of the blacks in dropdown.
Cheers
Message 56 of 60
schlanz
in reply to: schlanz
Sry, i didnt see that there is a page 3 with an updated version. this one works great thx! just the question about the width is still open.
Message 57 of 60
anderson51
Is there a way to expand on this command, so that you can enter the name of the block in the command line vs. finding the name in the pull down menu?
This is a great command by the way.
Thank you
Anderson51
Message 58 of 60
_Tharwat
in reply to: anderson51
Thank you
Anderson51
I worked hard on this program on my own volunteering time, so if you want me to modify the program as per your requirements then just contact me on my website as shown in my signature or as a private message.
Message 59 of 60
mneesley
ErmaGERD 7 years later and this is STILL AWESOME 😁
Message 60 of 60
_Tharwat
in reply to: mneesley
Thank you for your kind words. 😊
”Boost
