Visual LISP, AutoLISP and General Customization
Selection Prompt in command line
4 REPLIES 4
JCprog
357 Views, 4 Replies
Hello Everyone 🙂
Im trying to implement Lee's selection prompt but can't get it to work (see code below). Please help.....
(defun c:PROCMAIN1 ()
(initget "Alpha Beta Gamma")
(if (= "Alpha" (getkword "\nChoose [Alpha/Beta/Gamma]: "))
    (c:Alpha)
	(= "Beta" (getkword "\nChoose [Alpha/Beta/Gamma]: "))
    (c:Beta)
	(= "Gamma" (getkword "\nChoose [Alpha/Beta/Gamma]: "))
    (c:Gamma)
  (princ)
4 REPLIES 4
Kent1Cooper
in reply to: JCprog
In order to use (initget) only once, you would need to set a variable with the User's choice in it, and then work with what they chose.  It could be done with separate (if) tests, but in a situation like this with more than two possibilities, the (cond) function is the best way to go.  Something like:
(defun c:PROCMAIN1 (/ choice)
  (setq choice (getkword "\nChoose [Alpha/Beta/Gamma]: "))
  (cond
    ((= choice "Alpha") (c:Alpha))
    ((= choice "Beta") (c:Beta))
    ((= choice "Gamma") (c:Gamma))
  (princ)
Or, since the option words are the same as the command names, this shorter version also works:
  (eval (read (strcat "(C:" choice ")")))
  (princ)
EDIT:  Also consider doing this, to force the User to make one of those choices by forbidding Enter:
  (initget 1 "Alpha Beta Gamma")
Kent Cooper, AIA
_Tharwat
in reply to: JCprog
Read about COND function
JCprog
in reply to: Kent1Cooper
Thanks you much Kent! Works flawlessly Smiley Very Happy
JCprog
in reply to: _Tharwat
Thanks for your reply Tharwat.....I will look into it 🙂
”Boost
