I am trying to create a lisp that will select all objects on all layers whos linetype property is not equal to continuous. My ultimate goal is to select all lines and turn them to layer 0 but keep the original line type.
For example:
all lines are set to linetype: by layer
layer list:
lay1 linetype: continuous
lay2 linetype: continuous
lay3 linetype: continuous
lay4 linetype: hidden2
lay5 linetype: hidden2
lay6 linetype: phantom
I want to select everything on lay4, lay5, and lay6 and change the linetype overwrite from "bylayer" to "hidden2" so that when I change them over to layer 0, the line will still look hidden2.
Thank you for your help
Have a great day!!!
Solved by Kent1Cooper. Go to Solution.
Welcome to the Forums!
This kind of thing comes up here now and then, in fact a couple of times quite recently, for example here. What you'll find there may be more extensive than you need [designed to do everything in the drawing, and there are links to things to do everything in Block definitions], but could be pared down to do a little less, if you prefer.
Thank you!! This pointed me in the corect direction. I appologize for the delayed reply. I appreciate your help.
Have a great week!!!!
