Hi friends,
I need a LISP program that prompts: "select text(s)" then I select for example 100 text in open drawing file.
after that this program creat a file (LIST.CSV) and write each selected text in line by line of this file:
result text file (LIST.CSV ) should be:
Text1
Text2
Text3
Text99
Text100
ofcourse Text1 is the content of a text object.
Thank you in advance
Solved by pbejse. Go to Solution.
Can it you help?
(defun c:text_value2csv ( / js dxf_cod mod_sel n lremov file_name cle f_open ename l_pt l_pr nbs) (princ "\nChoice of an object models for filtration: ") (while (null (setq js (ssget "_+.:E:S" (list '(0 . "*TEXT") (cons 67 (if (eq (getvar "CVPORT") 1) 1 0)) (cons 410 (if (eq (getvar "CVPORT") 1) (getvar "CTAB") "Model")) ) ) ) ) (princ "\nIt is not a valid object for this function!") ) (vl-load-com) (setq dxf_cod (entget (ssname js 0))) (foreach m (foreach n dxf_cod (if (not (member (car n) '(0 67 410 8 6 62 48 420 70))) (setq lremov (cons (car n) lremov)))) (setq dxf_cod (vl-remove (assoc m dxf_cod) dxf_cod)) ) (initget "Single All Manual") (if (eq (setq mod_sel (getkword "\nMode of filtered selection, choice[Single/All/Manual]<Manual>: ")) "Single") (setq n -1) (if (eq mod_sel "All") (setq js (ssget "_X" dxf_cod) n -1) (setq js (ssget dxf_cod) n -1) ) ) (setq file_name (getfiled "Name of the file has create?: " (strcat (substr (getvar "dwgname") 1 (- (strlen (getvar "dwgname")) 3)) "csv") "csv" 37)) (if (null file_name) (exit)) (if (findfile file_name) (progn (prompt "\nFile already exists!") (initget "Add Replace Undo") (setq cle (getkword "\nDatas in file? [Add/Replace/Undo] <Replace>: ") ) (cond ((eq cle "Add") (setq cle "a") ) ((or (eq cle "Replace") (eq cle ())) (setq cle "w") ) (T (exit)) ) (setq f_open (open file_name cle)) ) (setq f_open (open file_name "w")) ) (repeat (sslength js) (setq ename (vlax-ename->vla-object (ssname js (setq n (1+ n)))) l_pt nil) (setq l_pr (list 'TextString) nbs 0) (foreach n l_pr (if (vlax-property-available-p ename n) (setq l_pt (cons (vlax-get ename n) l_pt) ) ) ) (foreach n l_pt (write-line n f_open) ) (write-line "" f_open) ) (close f_open) (prin1) )
Hi my friend,
I just want to select text then program filter text with "/" symbole. if selected text has one "/" character in content then accepted it and finally sort all of this selected text and put them as a Text File with same name of drwaing file.
for example, if I open "MyCAD23.dwg" file and select texts , then LISP program creat "MyCAD23.CSV" file and put all of selected text into this CSV file line by line. (one line for one text)
Text1
Text2
Text100
Thank you so much
Try this code
(defun C:TCSV (/ textdata txt file fname) (vl-load-com) (command "_zoom" "_e") (setq textdata (mapcar '(lambda(x)(cdr (assoc 1 x))) (mapcar 'entget (vl-remove-if 'listp (mapcar 'cadr (ssnamex (ssget "_X" (list (cons -4 "<and") (cons 0 "TEXT") (cons 1 "*/*") (cons 410 (getvar 'ctab)) (cons -4 "and>") ) ) ) ) ) ) ) ) (command "_zoom" "_p") (if textdata (progn (setq fname (strcat (getvar "dwgprefix") (vl-filename-base (getvar "dwgname")) ".csv")) (if (setq file (open fname "w")) (progn (setq i 0) (foreach txt textdata (write-line (strcat (itoa (setq i (1+ i))) "\t" txt) file) ) (close file) ) ) (alert (strcat "Texts saved to file: \n" fname)) ) ) (princ) ) (princ "\n\t\t--- Type TCSV to execute. ---") (prin1)
Hi my friend,
Thank you for your help, But this is not exactly what I want!
May you customize it as:
1- did not add number before texts
2-prompt "select object(s)" and apply filter for selected objects.
3-before write to file, sorting them, for e.g. by vl-sort '< function
3-did not shows any message or alert
Thank you so much in advance
What do you mean by this? say found string are /Banana and /Mango, what would be the result?
Banana1
Mango2
or
Banana 1?
Mango 2?
An alert or message informing the user the porgram is done processing?
Hi Pbejse,
in previous lisp program when I selected these text:
xc/56
45/cdv-f
ffg/hg67
ggh/gh-045
result is (filename.CSV):
1 xc/56
2 45/cdv-f
3 ffg/hg67
4 ggh/gh-045
but I want exactly text without prefix or suffix added. exactly these:
45/cdv-f
ffg/hg67
ggh/gh-045
xc/56
(Sorted result in CSV file)
So, I don't like to added sequential numbers before texts!! I want texts in line by line!
I prefer output csv file opens by Notepad and don't like to see a message!
Thank you so much
a couple questions:
"if selected text has one "/" character in content then accepted.."
don't include strings with two or more "/"?
"prompt "select object(s)" and apply filter for selected objects..."
If you'll be prompted to select text why the need for filter?
Why the need for CSV format?
Quickly written code
(defun c:w2csv (/ strs fname file i) (if (and (= (getvar 'DwgTitled) 1) (setq strs nil ss (ssget (list '(0 . "TEXT") (cons 1 "*/*"))) ) (setq fname (strcat (getvar "dwgprefix") (vl-filename-base (getvar "dwgname")) ".csv" ) ) (setq file (open fname "w")) ) (progn (repeat (setq i (sslength ss)) (setq strs (cons (cdr (assoc 1 (entget (ssname ss (setq i (1- i)))) ) ) strs ) ) ) (foreach itm (vl-sort strs '<) (write-line itm file) ) (close file) (startapp "Notepad" fname) ) ) (princ) )
Hi, Pbejse,
-> one or more "/" is acceptable. (at least one)
-> because I need to export a part of texts inside drawings.
some of them have not "/" or even some of them are not text in my selection set.
--> because I want to import this file into another software that it just can import CSV format.
Thank you for your time and consideration
@aqdam1978 wrote:Hi, Pbejse,
Refer to my previous post aqdam for the test code and tell me what else is missing
Hi CADaStroumph,
This is an excellent tool, does exactly what I need.
Two questions however, the csv file puts a blank line between the data that is extracted, can this be deleted via the code, before the data is extracted?
And secondly, can the data be written to view horizontally not vertically in the csv file?
