Select Multiple Objects
4 REPLIES 4
505 Views, 4 Replies
I cannot seem to figure out how I can make this pick more than one object. I know that it must be realatively simple, but everything that I have tried has not worked. Can someone help?
(defun C:MM-BYBLOCK ( / ENT SCMDE SORMOD VLAY)
(setq SOSMOD (getvar "osmode")) ; captures current snap settings
(setq SCMDE (getvar "cmdecho")) ; capture current setting
(setq SORMOD (getvar "orthomode")) ; capture current setting
(setvar "cmdecho" 0) ; stop screen output
(setvar "osmode" 0) ; set osnap to none
(setvar "orthomode" 0) ; set ortho off
(setq ENT (entsel "\nSelect Object :"))
(command "change" ENT "" "p" "la" "0" "C" "byblock" "")
(setvar "cmdecho" SCMDE) ; reset
(setvar "orthomode" SORMOD) ; reset
(setvar "osmode" SOSMOD) ; reset snap mode
(gc)
(princ)
4 REPLIES 4
Kent1Cooper
Use (ssget) rather than (entsel) if you want more than one object.
Kent Cooper
dvenerem wrote...
I cannot seem to figure out how I can make this pick more than one object....
Kent Cooper, AIA
I did put this in my code, but it does not seem to work. Can you elaborate a little more.
Kent1Cooper
It wouldn't work if you simply substitute the term "ssget" in place of "entsel" -- the functions use different arguments [e.g. you can't spell out a prompt in (ssget), but it has many powerful options that (entsel) doesn't]. See the AutoLisp Reference for details on how to use it -- that will be the best elaboration. If you try it and it doesn't work, you can post what you tried, and someone will probably be able to tell you how to fix it.
Kent Cooper
Kent Cooper, AIA
tcorey
Here's the code:
(setq SSET (ssget))
(command "change" SSET "p" "la" .......
Tim Corey
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
”Boost
