33 Kudos
Post 1 of 8
Select Layer by Color Lisp
1469 Views, 7 Replies
08-28-2011 09:42 AM
I am interested in a program that can select layers by its color, and then change those layers to a different color and add a prefix of Z- in front of those layers.
Example:
Layer Names:   Layer Color:   New Layer Names:   New Layer Color:
Wall                         2                    Z-Wall                       100
Berm                       2                     Z-Berm                     100
Fence                     2                     Z-Fence                   100
I found a program (below) that works pretty close to what I am looking for but not quite.
;;;  Change the color of a layer to another color by Jeff Mishler July 9, 2003
;;;  Usage - (lay_col_chg oldcolor newcolor
;;;  example: Command: (lay_col_chg 142 100)
(defun lay_col_chg (oldcolor newcolor / layers)
(vl-load-com)
(setq layers (vla-get-layers
(vla-get-activedocument
(vlax-get-acad-object))))
(vlax-for x layers
(if (= oldcolor (vla-get-color x))
(vla-put-color x newcolor)
(princ)
Thanks ahead of time for your help.
azrdgldr wrote:
Lee, thanks for your reply and code.  I should have elaborated my requests a little further.  I was hoping for something more like prompting me for the color of the existing layers and also for the color of the new layer.
No worries, try something like this:
(defun c:dolayers ( / c1 c2 nm pr )
(if
(and
(princ "\nSelect Existing Layer Color...")
(princ)
(setq c1 (acad_colordlg 7 nil))
(princ "\nSelect New Layer Color...")
(princ)
(setq c2 (acad_colordlg 7 nil))
(setq pr (getstring t "\nSpecify Layer Prefix: "))
(vlax-for layer (vla-get-layers (vla-get-activedocument (vlax-get-acad-object)))
(if
(and
(= c1 (vla-get-color layer))
(not (wcmatch (setq nm (vla-get-name layer)) (strcat pr "*")))
(not (tblsearch "LAYER" (setq nm (strcat pr nm))))
(progn
(vla-put-color layer c2)
(vla-put-name layer nm)
(princ)
(vl-load-com) (princ)
azrdgldr wrote:
On another note I took a look at your layerextract tool to see if I could use it for this instance, which didn't look like I could, but nice program though.
Thanks azrdgldr, I'm glad you like the program - unfortunately it can only to be used for extracting data however :smileywink:
332 Kudos
Post 2 of 8
Re: Select Layer by Color Lisp
08-28-2011 09:53 AM in reply to: azrdgldr
The most intuitive way would be to iterate through the Layer Collection and use a conditional statement to test for the desired properties of the layers to be changed:
e.g.:
(defun c:dolayers ( / name )
        (if
            (and
                (= 2 (vla-get-color layer))
                (not (wcmatch (setq name (vla-get-name layer)) "Z-*"))
                (not (tblsearch "LAYER" (setq name (strcat "Z-" name))))
            (progn
                (vla-put-color layer  100)
                (vla-put-name  layer name)
    (princ)
Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
Expert Elite
With Mathematics there is the possibility of perfect rigour, so why settle for less?
33 Kudos
Post 3 of 8
08-28-2011 10:25 AM in reply to: Lee_Mac
Lee, thanks for your reply and code.  I should have elaborated my requests a little further.  I was hoping for something more like prompting me for the color of the existing layers and also for the color of the new layer.  On another note I took a look at your layerextract tool to see if I could use it for this instance, which didn't look like I could, but nice program though.
332 Kudos
Post 4 of 8
08-28-2011 10:40 AM in reply to: azrdgldr
    (if
        (and
            (princ)
            (princ)
            (if
                (and
                (progn
    (princ)
Expert Elite
33 Kudos
Post 5 of 8
08-28-2011 10:44 AM in reply to: Lee_Mac
Works great.  Thanks for your help on this.
332 Kudos
Post 6 of 8
08-28-2011 11:03 AM in reply to: azrdgldr
You're welcome azrdgldr :smileyhappy:
Expert Elite
33 Kudos
Post 7 of 8
08-28-2011 11:29 AM in reply to: Lee_Mac
I have only stuck my toes in to check the temperature when it comes to Vl- commands and their usage.  You and Kent make this stuff look so easy and I do mean easy.  I still consider myself a hacker at this even though I have written quite a few programs.  I know now that I just have to jump in no matter what and see if I sink or swim in VL-.  Thanks again.
332 Kudos
Post 8 of 8
08-28-2011 02:55 PM in reply to: azrdgldr
Thanks azrdgldr :smileyhappy:
Once you have a basic understanding of the underlying structure of the AutoCAD Object Model*, and how to work with properties and methods derived from objects in the model, the best way to learn is to experiment and post a question when you get stuck; then learn from the mistakes that you make.
Studying the code posted by others on the forums is also a great benefit, (just make sure that you study code from a good source :smileywink:), but when you attempt a program yourself you realise where your knowledge is lacking and the parts that you need to study some more.
*For what its worth, I wrote a brief intro to the Object Model in a post at CADTutor here, I'm not sure of your level at VL programming, but maybe it will be of some benefit to your learning.
Hope this helps,
Lee
Expert Elite
