using autolisp or visual lisp I want to open "Select Color Dialog Box" http://exchange.autodesk.com/autocadarchitecture/enu/online-help/browse#WS1a9193826455f5ffa23ce210c4... and get RGB color code to my lisp.
If I enter "color" in command line, i get color dialog box, but if I use this command in (command "color") I get more promts and not color Dialog Box.
I want to make a lisp routine which would ask for first color, second color and range of colors. And will calculate color range from first color to second color.
Thanks.
Solved by _Tharwat. Go to Solution.
Solved by hmsilva. Go to Solution.
Shinigami_black,
look in
"acad_truecolordlg" and "acad_colordlg" functions
hope that helps
Henrique
it is just what was necessary.
But I do not understand true color code returned from acad_truecolordlg. This one (420 . 7022356). It should be (“Red,Green,Blue”), but is some big number. How can I convert it to red,green,blue?
7022356 is color 107,39,20 in select color box.
Look in "color-util.lsp", from Autodesk, should be in the AutoCAD, Sample folder...
Henrique
found it in my installation DVD. Half of Sample catalog is not installed.
Result:
(defun MakeColorRange (firstColor secondColor colorRange / rangeRed rangeGreen rangeBlue result) (setq rangeRed (fix (/ (- (car firstColor) (car secondColor)) colorRange))) (setq rangeGreen (fix (/ (- (cadr firstColor) (cadr secondColor)) colorRange))) (setq rangeBlue (fix (/ (- (caddr firstColor) (caddr secondColor)) colorRange))) (setq result (cons firstColor (setq result (list)))) (repeat colorRange (setq firstColor (list (- (car firstColor) rangeRed) (- (cadr firstColor) rangeGreen) (- (caddr firstColor) rangeBlue))) (setq result (cons firstColor result)) ) (reverse result) ) (defun C:ColorScheme ( / firstColor secondColor colorRange) (setq firstColor (TrueColor-split (cdr (assoc 420 (acad_truecolordlg '(420 . 2686760) nil))))) (setq secondColor (TrueColor-split (cdr (assoc 420 (acad_truecolordlg '(420 . 2686760) nil))))) (setq colorRange (- (getint "\n Enter color range number: ") 1)) (princ (MakeColorRange firstColor secondColor colorRange)) (princ) )
