Visual LISP, AutoLISP and General Customization
Select all blocks in paperspace
9 REPLIES 9
Message 1 of 10
embolisim
1815 Views, 9 Replies
Hi, this is probably a newbie question sorry, I dont do much lisping.
I want to select all blocks in paperspace for the purpose of deleting it. The file is a revit export and I know very well that the only block is the title block.
This selects all paperspace objects successfully;
(setq sstb (ssget "x" '(67 .1)(command "select" sstb)))
but when I try to filter out everything that is not a block like this;
(setq sstb (ssget "x" '(67 .1)(0 . "BLOCK")(command "select" sstb)))
my selection set is empty.
Any help much appreciated.
Thanks....
9 REPLIES 9
Message 2 of 10
embolisim
in reply to: embolisim
just ignore me I was talking gibberish... none of that worked anyway, but this does.
(setq sstb (ssget "X" (list (cons 0 "INSERT")(cons 67 1))))
(setq ssreminder "\ntake meds before posting on forums")
Message 3 of 10
Any advice for how to use that string for this noob ? I need to select only paperspace objects (indeed blocks) too. How do i use that string to select them ?
Deniz
Message 4 of 10
Deniz,
the group code 67 it's a flag, if it's 1 indicates that the entity is in paper space, if zero or absent indicates that the entity is in model space.
So from the code string
(setq sstb ;; sets to the sstb variable re resulting selection set
(ssget "X" ;; search the entire drawing database
(list ;; filter list
(cons 0 "INSERT") ;; must be an INSERT entity
(cons 67 1) ;; must be in paper space
) ;; end the filter list
) ;; end the ssget function
) ;; end the setq function
You can also use
(setq sstb (ssget "X" (list (cons 0 "INSERT") (cons 410 "~Model") )))
the group code 410 is the Layout name, and with a tilde preceding the name, means except that name, will accept as valid layaut name all except "Model"
Hope that helps
Henrique
Message 5 of 10
Henrique,
Can you pls tell me how can i use that code string ? ( I remember that when i asked this question i found the answer but now i forgot 😄
Thnx
I already copied and pasted that to command bar but it does not select the blocks in the paperspace ?
PS: ( I'm seeking for the answer because, all i want to do is to change the titleblock attributes whenever it is necessary. So Right now i finished my dynamic block but, it seems that i can't select all the title blocks i have pasted to each layout ?
Deniz
Message 6 of 10
Hi Deniz,
with
(setq ss (ssget "_X" '((0 . "INSERT") (410 . "~Model") (66 . 1))))
you should ceate a selection set with all blocks with attributes in all layouts, except in model space, and set the 'ss' variable with it.
Henrique
Message 7 of 10
Nope, It seems that it does not work for me. I attached the file. What i need to do is to make an attout and attin for those titleblocks, in my layouts.
Hope i could define enough.
I pasted that code in the command bar but again did not worked. Here is a screenshot.
Deniz
Message 8 of 10
Deniz,
at the moment I don't have AutoCAD with me, but try
(if (setq ss (ssget "_X" '((0 . "INSERT") (410 . "~Model") (66 . 1))))(sssetfirst nil ss))
Henrique
Message 9 of 10
It works like a charm. I still did not tested extensively but, i can say that it works with the test file i sent to you. Thanks a lot.
Cheers
Deniz
Message 10 of 10
You're welcome, Deniz
Glad I could help
Henrique
”Boost
