Hi all,
I'm working out a LISP for searching my entire drawing for a MLeader with a given value and then do something if it is found.
Currently, my code dies with
; error: Automation Error. Description was not provided.
I do not know what is going wrong & I don't know what must be done next.
(DEFUN ML-SRCHSTR (TXT LBL / SS n_txt_LBL ENT P1 P2) ;|(ML-SRCHSTR TXT)|; (IF (SSGET "x" '((0 . "MULTILEADER"))) (PROGN (SETQ ss (VLA-GET-ACTIVESELECTIONSET (VLA-GET-ACTIVEDOCUMENT (VLAX-GET-ACAD-OBJECT)))) (VLAX-FOR ent ss (IF (VL-STRING-SEARCH txt (STRCASE (VLA-GET-TEXTSTRING ent))) (PROGN (VLA-CLEAR ss) (INITGET 1 "Yes No") (SETQ n_txt_LBL (STRCAT "\n\t =>> " LBL " Label EXISTS! Add another " txt "? ") y_n (GETKWORD (strcat n_txt_LBL " [Yes/No]: ")) ) (IF (= y_n "Yes") (PROGN (ppa-L-PLANTXT) (VL-CMDF "cmleaderstyle" "LandscapeQua") (INITGET 1) (SETQ P1 (GETPOINT "\n\t =>> Specify leader start point: ") P2 (GETPOINT P1 "\n\t =>> Specify next point: ") ) (VL-CMDF "_.mleader" P1 P2 txt) ) ) ) ) ) (IF (> (VLA-GET-COUNT ss) 0) (PROGN (ppa-L-PLANTXT) (VL-CMDF "cmleaderstyle" "LandscapeQua") (INITGET 1) (SETQ P1 (GETPOINT "\n\t =>> Specify leader start point: ") P2 (GETPOINT P1 "\n\t =>> Specify next point: ") ) (VL-CMDF "_.mleader" P1 P2 txt) ) ) ) (PROGN (ppa-L-PLANTXT) (VL-CMDF "cmleaderstyle" "LandscapeQua") (INITGET 1) (SETQ P1 (GETPOINT "\n\t =>> Specify leader start point: ") P2 (GETPOINT P1 "\n\t =>> Specify next point: ") ) (VL-CMDF "_.mleader" P1 P2 txt) ) ) )
FYI - (ppa-L-PLANTXT) only sets my current layer.
My MLeader has a _TagBox & it is the attribute of the _TagBox that I am trying to check/compare the "txt" value.
Any help is greatly appreciated.
Solved by pbejse. Go to Solution.
You have to step through the mleader's attributes and check the value from there. Issue is, if I remember correctly, there was a bug with attributed mleaders where you can't extract the textstring from each attribute. There's all kinds of issues when working with mleaders.
I hope I can be corrected on this. 😕
Hi mid-awe, can you post a sample drawing (2010)?
"How we think determines what we do, and what we do determines what we get."
BlackBoxCAD,
Thanks for taking a look. I've attached an example with 3 MLeaders each with different attribute values.
mid-awe.
as alanjt_ already said, there are problems accessing to the attibutes in attributed mleaders, as vla objects...
One way to accessing to the text string in a attributed mleader, is is through the entity data.
Untested...I don't have Autocad in this laptop
(DEFUN ML-SRCHSTR (TXT LBL / SS n_txt_LBL ENT P1 P2) ;|(ML-SRCHSTR TXT)|; (IF (setq ss (SSGET "x" '((0 . "MULTILEADER")))) (PROGN (setq itm 0 num (sslength ss)) (while (< itm num) (setq edata (entget (ssname ss itm))) (IF (equal txt (cdr (assoc 302 (member (cons 304 "LEADER_LINE{") edata)))) (PROGN (VLA-CLEAR ss) (INITGET 1 "Yes No") (SETQ n_txt_LBL (STRCAT "\n\t =>> " LBL " Label EXISTS! Add another " txt "? ") y_n (GETKWORD (strcat n_txt_LBL " [Yes/No]: ")) ) (IF (= y_n "Yes") (PROGN (ppa-L-PLANTXT) (VL-CMDF "cmleaderstyle" "LandscapeQua") (INITGET 1) (SETQ P1 (GETPOINT "\n\t =>> Specify leader start point: ") P2 (GETPOINT P1 "\n\t =>> Specify next point: ") ) (VL-CMDF "_.mleader" P1 P2 txt) ) ) ) ) (setq itm (1+ itm)) ) (IF (> (sslength ss) 0) (PROGN (ppa-L-PLANTXT) (VL-CMDF "cmleaderstyle" "LandscapeQua") (INITGET 1) (SETQ P1 (GETPOINT "\n\t =>> Specify leader start point: ") P2 (GETPOINT P1 "\n\t =>> Specify next point: ") ) (VL-CMDF "_.mleader" P1 P2 txt) ) ) ) (PROGN (ppa-L-PLANTXT) (VL-CMDF "cmleaderstyle" "LandscapeQua") (INITGET 1) (SETQ P1 (GETPOINT "\n\t =>> Specify leader start point: ") P2 (GETPOINT P1 "\n\t =>> Specify next point: ") ) (VL-CMDF "_.mleader" P1 P2 txt) ) ) )
Henrique
Can't wrap my head on what your routine is supposed to do, But to "catch" a specific TAG
(defun c:Demo (/ _MLAttValue BlockColl ss i e f) (vl-load-com) ;;; pBe 22May2013 ;;; ;; Demo for Mtext Block Attribute ;;; (defun _MLAttValue (en et tag coll / n i attag) (setq n -1 i (1- (vla-get-count et)) ) (while (and (null attag) (< n i)) (if (And (eq "AcDbAttributeDefinition" (vla-get-ObjectName (setq x (vla-item et (setq n (1+ n))))) ) (eq tag (vla-get-TagString x)) ) (setq attag (vla-getBlockAttributeValue en (vla-get-ObjectID x))) ) ) ) (setq BlockColl (vla-get-blocks (vla-get-ActiveDocument (vlax-get-acad-object))) ) (if (setq ss (ssget "_:L" '((0 . "MULTILEADER")))) (repeat (setq i (sslength ss)) (setq e (vlax-ename->vla-object (ssname ss (setq i (1- i))))) (if (And (Eq (vla-get-ContentBlockName e) "_TagBox") (setq f (_mlattvalue e (vla-item BlockColl "_TagBox") "TAGNUMBER" BlockColl ) ) ) (princ (Strcat "\nDo your thing here with the value: \"" f "\"")) (princ "\nTag not Found:") ) ) )(princ) )
HTH
oops...
BlockColl;<---- What the ?!!??? No need for this: a leftover from my original sub
should be like htis
(_mlattvalue e (vla-item BlockColl "_TagBox") "TAGNUMBER")
And
to
(defun _MLAttValue (en et tag / n i attag)
My bad
In addition there is my 2c
(defun C:MTF(/ *error* _getids en ids matchstr mleadobj sset) (vl-load-com) (defun *error* (s) ;(vl-bt) (setvar "nomutt" 0) (and s(princ s))) ;; local subfunction (defun _getIds (blockname / blk ids) (setq blk(vla-item (vla-get-blocks (vla-get-activedocument(vlax-get-acad-object) )) blockname)) (vlax-for item blk (if (eq "AcDbAttributeDefinition" (vla-get-objectname item)) (setq ids (cons (vla-get-objectid item)ids)) )) (reverse ids)) ;;main part (if (not (tblsearch "block" "NOTES")) (progn (alert "Add before block named \"NOTES\" before") (exit) (princ))) (princ "\nSelect mleaders") (setvar "nomutt" 1) (if (and (setq matchstr "Office Plan\\PFloor 7");<-- string to search you may use getstring for input (setq sset (ssget (list (cons -4 "<and") (cons 0 "multileader") (cons -4 "<not") (cons -4 "<or") (cons 296 0) (cons 296 1) (cons -4 "or>" ) (cons -4 "not>") (cons -4 "and>") )))) (while (setq en(ssname sset 0)) (setq mleadobj (vlax-ename->vla-object en)) (if (eq "NOTES"(vla-get-contentblockname mleadobj))(progn (setq ids (_getIds "NOTES")) (foreach id ids (if (eq matchstr (vla-GetBlockAttributeValue mleadobj id)) ;; If the text is found then change the color of mleader (vla-put-color mleadobj 1)))))(ssdel en sset ))) (*error* nil) (princ) )
