Visual LISP, AutoLISP and General Customization
script to explode mtext
6 REPLIES 6
2018 Views, 6 Replies
Hi guys,
I'm trying to explode mtext in a number of our dwgs, here's whaat i've come up with.
EXPLODE
(ssget "X" '((0 . "MTEXT")))
it works fine if i run it at the command prompt but not if i run it via script?
What am i not getting??
B
6 REPLIES 6
scot-65
A few of the LISP expressions are not allowed while inside a command.
Try restructuring:
(setq s (ssget...
(command "EXPLODE" s "")
(setq s nil)
[untested]
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
in reply to: scot-65
Hi scot-65,
well i've tried:
(setq mt (ssget "X" '((0 . "MTEXT")))
(command "EXPLODE" mt "")
(setq mt nil)
but it doeesn't work, i'm a novice at the ssget thing so it maybe something i'm just not getting right
B
Shneuph
For some reason the explode command doesn't accept the entire selection set.  I tried your code and with the exception of a missing close parenthesis it seemed like it should have worked.  I fixed that but it only exploded 1 of the mtext objects in the sslist.  This code adds them to an entitylist and then explodes each one...
(setq mt (ssget "X" '((0 . "MTEXT"))))
(setq ctr 0)
(while (setq cent (ssname mt ctr))
 (Setq objlist (append (list cent) objlist))
 (setq ctr (1+ ctr))
);while
(foreach mtextobj objlist
  (command ".explode" mtextobj)
);foreach
(setq mt nil
      ctr nil
      objlist nil)
@Anonymous wrote:
(setq mt (ssget "X" '((0 . "MTEXT"))) <-- Missing ) here.
BTW.. you can see that your code works if you run this line (setq mt (ssget "x" '((0 . "MTEXT")))) and then run (sslength mt)  That should return the count of objects in your mt selection set.
BTW #2.. If you also do (setq mt (ssget "x" '((0 . "MTEXT")))) and then (command "move" mt "")  see what happens...
---sig---------------------------------------
'(83 104 110 101 117 112 104 64 71 109 97 105 108 46 99 111 109)
in reply to: Shneuph
**** parenthesis!!
Thanks that's exxcellent!! work a treat!!
B
Kent1Cooper
@Shneuph wrote:
For some reason the explode command doesn't accept the entire selection set.  ...it only exploded 1 of the mtext objects in the sslist.  ....
This has come up several times before -- search the discussion group for Explode and the mysterious QAFLAGS System Variable.
Kent Cooper, AIA
Try this:
(defun C:MTXEX ( / ss )
  (setvar "QAFLAGS" 1)
  (setq ss (ssget "x" (list (cons 0 "MTEXT"))))
    (if ss
      (command "._EXPLODE" ss "")
  (setvar "QAFLAGS" 0)
(princ "\n** Type MTXEX to invoke **")
(princ)
peszel
”Boost
