Scale Uniformly
14 REPLIES 14
Message 1 of 15
961 Views, 14 Replies
Scale Uniformly
ok i give up trying to find the answer, i don't think anybody else ever tried this...
what i want to do, is to set a block that is pre-existing in the drawing that isn't set to scale uniformly to scale uniformly, i don't exacly know why, the scale command would probably be faster, but i think it would just be nice to have that set in some of the old blocks that i keep coming across. any ideas would be awesome, i've been trying to figure it out for a while and it's just not working.
14 REPLIES 14
Message 2 of 15
I don't quite understand what you want, so let me show some examples of what
I think you may be saying.
ie 1 (x3)
x = 1 now = 3
y = 2 now = 6
z = 0 now = 0
ie 2 (x3)
x = 1 now = 3
y = 2 now = 3
z = 0 now = 3
Am I close on either one?
Tim
"A blind man lets nothing block his vision."
wrote in message news:5259630@discussion.autodesk.com...
tried this...
Message 3 of 15
> of what I think you may be saying.
My guess.
> ie 2 (x3)
> x = 1 now = 3
> y = 2 now = 3
> z = 0 now = 3
Message 4 of 15
no, you know when you go into the block editor and in the properties thing you can set the "Scale Uniformly" to yes or no, i want to do the same thing with lisp.
i just made a lisp routing to scle blocks thru entmod stuff, but i really just want that scale uniformly thing to be set to yes in all my blocks, it's so rare that i would not scale a block uniformly that it should be the option, not the default. so i want to automate that in the drawings when i open them, but first i need to figure out where that little bugger lives so i can catch him and mod him B]
Message 5 of 15
(vlax-for blk
(vla-get-blocks
(vla-get-activedocument
(vlax-get-acad-object)
(vla-put-blockscaling blk acUniform)
wrote in message news:5259657@discussion.autodesk.com...
with lisp.
Message 6 of 15
ok, i'm retarded, i can't get it to work
Message 7 of 15
tader1
what I do is use the filter command then, "add selected object" then remove all things that are unique to that object, ie. coordinates, etc- then I select all. Then I use the properties dialogue box "ctrl+1" and u can change the scale to whatever you like there and many other attributes.
Message 8 of 15
yeah, and that is one way that i do it when i want to do a global change like that, but what i'm saying isn't to do a global scaling of all the blocks, i just want to be able to highlight the few blocks that need to be scaled and it's just easier to change a single value in the properties dialoge than to enter the same one three times. i'm mostly just being lazy, or anal, whichever it is, i did come up with a little routine out of this, most of the time i'm just scaling blocks dow from 1 to 0.8:
(defun c:sd ()
(while
(progn
(princ "\nScale Down ")
(setq en1 nil
en2 nil
en1 (entget (setq en (car (entsel))))
en2 (cdr (assoc 0 en1))
(while (/= en2 "INSERT")
(setq en1 nil
en2 nil
en1 (entget (car (entsel)))
(setq en1 (subst (cons 41 0.8) (assoc 41 en1) en1)
en1 (subst (cons 42 0.8) (assoc 42 en1) en1)
en1 (subst (cons 43 0.8) (assoc 43 en1) en1)
(entmod en1)
(entupd en)
(princ)
Message 9 of 15
tader1
lisp is cooler too
Message 10 of 15
i agree, lisp rocks!!
Message 11 of 15
There's no need to run entsel twice, and your variables should be declared local.
[code]
(defun c:sd (/ pick ename edata)
(while (not pick)
(setq pick (entsel)))
(setq
ename (car pick)
edata (entget ename))
(entmod
(subst '(41 . 0.8) (assoc 41 edata)
(subst '(42 . 0.8) (assoc 42 edata)
(subst '(43 . 0.8) (assoc 43 edata) edata))))
(entupd ename)
(princ))
[/code]
Message 12 of 15
i never really understood what the brackets after the defun meant, but now i think i understand, thanks! that should make things a bit easier.
Message 13 of 15
It's covered in the Developer documentation under "Using defun to Define a Function." The items listed after the slash are variables which are local to the function. Meaning that they are initally nil, and are shielded from the rest of the Acad session.
Message 14 of 15
guess i probably could have read that, but mostly i leared by just reading over other peoples routines so some stuff that i do i'm not sure why i do it i just do, but i mosly understand what's going on now. at some point in time i must have learned that my routines were working without adding all the variables at the baginnning an then just stopped defining them. thanks for the bit of education.
Message 15 of 15
so i finally got this to work using a macro instead. below is my solution for anyone who would like to do the same thing...
Lisp part:
(defun c:bsu ()
(princ "\nBlock Scale Uniformly\n")
(vl-vbaload (strcat home "/vba/timVBA.dvb"))
(vl-vbarun "block_scale_uniformly")
(princ "\nFinally!!\n")
(princ)
VBA Part:
Public Sub block_scale_uniformly()
Dim block As AcadBlock
Dim entity As AcadEntity
For Each block In ThisDrawing.Blocks
If "*Model_Space" = block.Name Or "*MODEL_SPACE" = block.Name Then
GoTo nextblock
Else
If "*Paper_Space" = block.Name Or "*PAPER_SPACE" = block.Name Then
GoTo nextblock
Else
block.BlockScaling = acUniform
End If
End If
nextblock:
Next block
End Sub
let me know if this is any help to anyone!
”Boost
