Active Contributor
0 Kudos
Post 1 of 6
Saveas using Lisp Or Vlisp
265 Views, 5 Replies
02-04-2013 05:12 AM
Is it possible to call the saveas command with the dialog showing with the filename already set by a variable?
Have already tried (initdia)(command "saveas" "" "MyDrawing") and (initdia)(vl-cmdf "saveas" "" "MyDrawing").
If running from a new file the filename in the dialog is always populated as "Drawing1"
Thanks Kent. That does the trick if it can't be done direct from the command.
667 Kudos
Post 2 of 6
Re: Saveas using Lisp Or Vlisp
02-04-2013 05:54 AM in reply to: macuma
Look into the (getfiled) function, which has an argument for a default file name.
Kent Cooper
Active Contributor
0 Kudos
Post 3 of 6
02-04-2013 06:11 AM in reply to: Kent1Cooper
Active Contributor
0 Kudos
Post 4 of 6
02-20-2013 03:30 AM in reply to: macuma
Only just got round to fully testing this. It accepts the variables but can't be used to save, only to open an existing file.
Active Contributor
0 Kudos
Post 5 of 6
02-20-2013 03:44 AM in reply to: macuma
Sorry, this does work. Didn't read the flag settings correctly.
306 Kudos
Post 6 of 6
02-20-2013 03:46 AM in reply to: macuma
(setvar 'expert 5)
(setq fn (getfiled "Save drawing as" (strcat (getvar 'dwgprefix) var) "dwg" 1))
(command "_save" fn)
HTH
