Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<kevinmulvaney> wrote in messageThanks
href="news:6051957@discussion.autodesk.com">news:6051957@discussion.autodesk.com...
to all for the help. Through a load of trial and error I found a solution that
will work. I was trying to do too much, so i just added my lisp routine to the
acad.lsp file so it only runs on the inital startup. I kep running into the
problem of it running each time I opened a drawing. I guess I should start off
a bit smaller with the lisps, and work my way up. Again thanks to everyone for
the help.
Kevin
Scot-65
<kevinmulvaney> wrote in messageI
href="news:6052048@discussion.autodesk.com">news:6052048@discussion.autodesk.com...
only need it to run on initial startup. Otherwise it will close any drawing
that I open.
Thank you,
Kevin
