In acad 2009 (at work) and my I acad 2002 (at home) i can select the lisp window and then load it into the currend acad session, than re-select the window and run it.
But in 2010 and 2012 (a w) the run option is not selectable, i can still (load" ") and run the c: in the acad window but why not from the lisp editor so i can "Toggel break point" / "Add watch" "Last break" and check a few things.
This is with all lisp files !
Solved by Wheelie22. Go to Solution.
Note that the controls on the Debug Toolbar are not to 'run' the program, but to control the evaluation after a break point has been set.
After loading code through the VLIDE Editor window, you still need to start the program using the "c:" syntax.
