Visual LISP, AutoLISP and General Customization
Routine to sum multiples dimensions
5 REPLIES 5
FilRib
2354 Views, 5 Replies
What is my goal: to select multiple dimensions entities and obtain the sum os all of them. In the image below i should be albe to select the 2 dimensions and the result of the command/routines should respond me "5".
Someone know a routine/command for that?
Thanks in advance!
5 REPLIES 5
_Tharwat
in reply to: FilRib
Try ...
(defun c:Test (/ i ss )
  (if (setq i 0. ss (ssget '((0 . "*DIMENSION"))))
      ((lambda (% / sn)
         (while (setq sn (ssname ss (setq % (1+ %))))
           (setq i (+ (vla-get-measurement (vlax-ename->vla-object sn)) i))
        -1)
  (if (> i 0.)
    (princ (strcat "\nTotal measuremnts : < " (rtos i 2 4) " > ."))
  (princ)
  )(vl-load-com)
FilRib
in reply to: _Tharwat
Perfect!
Thank you very much!
_Tharwat
in reply to: FilRib
@FilRib wrote:
Perfect!
You are welcome .
oelgam23
how to use the code?thank you
_Tharwat
in reply to: oelgam23
Copy the codes and save them in a txt file with the extension .lsp then READ THIS to know how to load the program.
After you load the codes then just call the command name which is TEST
Good luck.
”Boost
