Visual LISP, AutoLISP and General Customization
routine doesn't work first time, but there after???
3 REPLIES 3
202 Views, 3 Replies
hi
i'm having a bit of trouble with the following routine... it removes a
vertex from a polyline. the problem is that it doesn't work the first time
its run, but works everytime after that.... any help would be great
cheers
mark
(defun C:RV (/ *CURR_OSNAP olderror
SelectedEntity PolyProperties iCount
iCount2 NewPoly
;;; does not change the vertex on the first run through
(setq *CURR_OSNAP (getvar "osmode"))
(setq olderror *error*)
(setq *error* RVLispError)
(setvar "cmdecho" 0)
(command "undo" "begin")
(setvar "osmode" 0)
(setq SelectedEntity (car (entsel "\nSpecify polyline: ")))
(if (and (/= SelectedEntity nil)
(= (cdr (assoc 0 (entget SelectedEntity))) "LWPOLYLINE")
(progn
(setq PolyProperties (entget SelectedEntity))
(initget 1)
(setvar "osmode" 32)
(setq SelectedVertex (getpoint "\nSpecify vertex to remove: "))
(setq iCount 0)
(while (< iCount (cdr (assoc 90 PolyProperties)))
(setq VertexPosition
(cdr (nth (+ (* iCount 4) 14) PolyProperties))
(if (and (= (car VertexPosition) (car SelectedVertex))
(= (cadr VertexPosition) (cadr SelectedVertex))
(progn
(setq iCount2 0)
(while (< iCount2 4)
(setq NewPoly
(vL-remove (nth (+ (* iCount 4) 14) PolyProperties)
PolyProperties
(setq iCount2 (1+ iCount2))
) ;while
(setq
NewPoly (subst
(cons
90
(1- (cdr (assoc 90 PolyProperties)))
NewPoly
(entmod NewPoly)
(entupd (cdr (assoc -1 NewPoly)))
(setq iCount (cdr (assoc 90 PolyProperties)))
) ;progn
) ;if
(setq iCount (1+ iCount))
) ;while
) ;progn
(prompt "\nNo polylines selected!")
) ;if
(RVCleanUp)
(princ)
(princ)
3 REPLIES 3
This works ok for me. I had to comment out (RVCleanUp) since you didn't
include it.
Maybe the problem is in there.
"Mark Dubbelaar" wrote in message
news:6FFD3A8291E473AEF4BB63E9B34B0629@in.WebX.maYIadrTaRb...
> hi
> cheers
> mark
> iCount2 NewPoly
> (setvar "osmode" 0)
> (progn
> (initget 1)
> (setq iCount 0)
> (progn
> (setq iCount2 0)
> (setq NewPoly
> PolyProperties
> ) ;while
> (setq
> NewPoly (subst
> (cons
> 90
> NewPoly
> (entmod NewPoly)
> ) ;progn
> ) ;if
> ) ;while
> ) ;progn
> ) ;if
> (RVCleanUp)
> (princ)
> (princ)
There's a vertex remover example on my Freebies page. Hope it helps.
John Uhden, Cadlantic/formerly CADvantage
http://www.cadlantic.com
Sea Girt, NJ
> hi
> cheers
> mark
> iCount2 NewPoly
> (setvar "osmode" 0)
> (progn
> (initget 1)
> (setq iCount 0)
> (progn
> (setq iCount2 0)
> (setq NewPoly
> PolyProperties
> ) ;while
> (setq
> NewPoly (subst
> (cons
> 90
> NewPoly
> (entmod NewPoly)
> ) ;progn
> ) ;if
> ) ;while
> ) ;progn
> ) ;if
> (RVCleanUp)
> (princ)
> (princ)
There's a vla function for vertex remove in www.acadx.com
Not affiliated
Rudy@Cadentity.com
AUTODESK
Authorized Developer
www.Cadentity.com
MASi
> hi
> cheers
> mark
> iCount2 NewPoly
> (setvar "osmode" 0)
> (progn
> (initget 1)
> (setq iCount 0)
> (progn
> (setq iCount2 0)
> (setq NewPoly
> PolyProperties
> ) ;while
> (setq
> NewPoly (subst
> (cons
> 90
> NewPoly
> (entmod NewPoly)
> ) ;progn
> ) ;if
> ) ;while
> ) ;progn
> ) ;if
> (RVCleanUp)
> (princ)
> (princ)
”Boost
