Visual LISP, AutoLISP and General Customization
Rotating a table to current UCS
1 REPLY 1
Redraiderr2009
658 Views, 1 Reply
Tables do no have a rotation angle. I can find the insert point, but there is no other point to make an angle calculation with.
(setq objTable (vlax-ename->vla-object (car (entsel))))
(vlax-dump-object objTable T)
1 REPLY 1
Rtogores
in reply to: Redraiderr2009
You may use vla-TransformBy with the UCS's transformation matrix.
To get the UCS transformation matrix it mus be a NAMED UCS.
This is a very simple example, it supposes your UCS is named previously:
(defun align-table  (/ table mtrans)
  (setq table (vlax-ename->vla-object
                (car (entsel "\nSelect Table:"))))
  (setq mtrans
         (vla-GetUCSMatrix
           (vla-get-ActiveUCS
             (vla-get-activedocument (vlax-get-acad-object)))))
  (vla-TransformBy table mtrans))
”Boost
