Visual LISP, AutoLISP and General Customization
Rotate Block by X-axis upon insert
19 REPLIES 19
Message 1 of 20
JCprog
1277 Views, 19 Replies
Hello Everyone Smiley Happy
I created a dynamic block (light pole) which have a stretch parameter for height adjustments. This can only be done with the pole laying down, so everytime the block is inserted it always needs to be 3d rotated. I found a routine that Lee Mac wrote which works really well. I just need it to include the "insert" part. Please help!
Here's the insert part:
-INSERT
"C:\\pole01.dwg"
s  r
 Here's the lisp from Lee
(defun c:bx90r ( / a e i p q r s x )
(setq a (/ pi 2.0))
(if (setq s (ssget "_:L" '((0 . "INSERT"))))
(repeat (setq i (sslength s))
(setq e (ssname s (setq i (1- i)))
x (entget e)
p (trans (cdr (assoc 10 x)) e 0)
r (cdr (assoc 50 x))
q (trans (mapcar '+ (cdr (assoc 10 x)) (list (cos r) (sin r) 0.0)) e 0)
(vlax-invoke (vlax-ename->vla-object e) 'rotate3d p q a)
(princ)
(vl-load-com) (princ)
Thanks in advance! Smiley Happy
19 REPLIES 19
Message 2 of 20
vivifira
in reply to: JCprog
two things.... you can use (command ".-insert" "C:\\pole01.dwg") and this will allow you insert set insertion point, scale and rotation of your block. you can add this to the beginning of your code by simply adding this just below the defun function and adding (command pause) right after this. so it should look something like this
(command pause)
(setq a (/ pi 2.0))
x (entget e)
(princ)
I hope this helps. 🙂
Message 3 of 20
smaher12
in reply to: vivifira
Or....
(command ".-insert" "C:\\pole01.dwg" pause "")
Without scale and rotate try...
(command ".-insert" "C:\\pole01.dwg" pause "" "" "")
Message 4 of 20
JCprog
Hi vivifira,
Thanks for the reply. The code didn't work, I get this error:
Command: BX90R
Unit-scaling inserted database...ADS request rejected
Command: '_.zoom _e
Command: '_.zoom _e
Command: '_.zoom _e
Command: '_.zoom _e
Command: '_.zoom _e
Command: BX90R ADS request rejected
Message 5 of 20
vivifira
in reply to: JCprog
Try this instead (command ".-insert" "C:\\pole01.dwg" 1 0 "") and no (command pause). let me know the results.
Message 6 of 20
JCprog
still no go....I get Value must be nonzero.
Message 7 of 20
hmsilva
in reply to: JCprog
(command ".-insert" "C:\\pole01.dwg" pause 1 "" pause)
EDIT:
"I created a dynamic block (light pole) which have a stretch parameter for height adjustments. This can only be done with the pole laying down, so everytime the block is inserted it always needs to be 3d rotated"
Could you attach your block?
HTH
Henrique
Message 8 of 20
JCprog
in reply to: hmsilva
This works in the exception of picking the inserterd block again. After picking the insertion point it should finish up with x rotation rather than picking the block again.
(setq a (/ pi 2.0))
x (entget e)
(princ)
Message 9 of 20
JCprog
Attached Block:
Message 10 of 20
hmsilva
in reply to: JCprog
Hi JCprog,
if you type at the command line
Command: -INSERT
and finalizing the block insertion, press F2 and copy/paste here the prompts.
EDIT: try
(command "_.-insert" "C:\\pole01.dwg" pause "" pause)
Henrique
Message 11 of 20
JCprog
in reply to: JCprog
Here's what I get:
Command: BX90R
.-insert Enter block name or [?] <pole01>:
C:\\pole01.dwg
Units: Inches   Conversion: 0'-1.0000"
Specify insertion point or [Basepoint/Scale/X/Y/Z/Rotate]:
Enter X scale factor, specify opposite corner, or [Corner/XYZ] <1>: 1 Enter Y
scale factor <use X scale factor>:
Specify rotation angle <0>:
Command:
Select objects: 1 found
Select objects:
Message 12 of 20
JCprog
this one returns "ADS request rejected"
Message 13 of 20
hmsilva
in reply to: JCprog
did you change the
(command "_.-insert" "C:\\pole01.dwg" pause 1 "" pause)
to
Henrique
Message 14 of 20
JCprog
This code is really close:
(setq a (/ pi 2.0))
x (entget e)
(princ)
 *It's just other users might pick the wrong block at the end of this routine.
Message 15 of 20
hmsilva
in reply to: JCprog
Change
to
(setq s (ssget "_L" '((0 . "INSERT"))))
HTH
Henrique
Message 16 of 20
JCprog
Yep! that perfected the code Smiley Very Happy
Thanks again Henrique!!!!! and also thanks to all who chipped in!!!!!
Message 17 of 20
hmsilva
in reply to: JCprog
You're welcome, JCprog
Glad I could help
Henrique
Message 18 of 20
vivifira
NP.... Just gald I could chip in. 🙂
Message 19 of 20
smaher12
in reply to: JCprog
Glad to see it is working....
Message 20 of 20
paullimapa
in reply to: JCprog
(setq pt (getpoint"\nPick Insertion Point: "))
(setq sc (getreal"\nEnter Scale: "))
(setq rt (/ (* (getangle"\nEnter Rotation: ") 180.0) pi))
(command"_.Insert""C:\\pole01.dwg" pt sc rt)
Paul Li
IT Specialist
@The Office
”Boost
