Visual LISP, AutoLISP and General Customization
Right mouse button screwed after new menu inserted
12 REPLIES 12
Message 1 of 13
144 Views, 12 Replies
Hi all. After I creaetd a new menu (For inserting blocks, I used a slide
library and did it that way) my right mouse button is totally screwed.
It adds extra characters to commands on the command line instead of being
enter like usual. I can't shift-right click for osnaps, or anything.
And if this is a setting in AutoCAD I'm going to scream because that is
about the most useless setting I could ever think of. Would you like to use
your right mouse button? Gee, no thanks, I'll just use the keyboard!
Acad version LT97
Sincerely,
Brent U
(Up in a tower with a gun)
12 REPLIES 12
Message 2 of 13
Sounds like your menu . You *are* making custom menus in a separate menu
file, right? Check the AUX menu section against a known good copy.
http://www.acadx.com
"Brent Upton" wrote in message
news:F6E76776920E54BD27E2377066E2EA9A@in.WebX.maYIadrTaRb...
use
| Acad version LT97
| Sincerely,
| Brent U
Message 3 of 13
Of course. and here it is.
// AutoCAD LT menu file - C:\Program Files\AutoCAD LT
97\standard_blocks.mnu
***MENUGROUP=Block_Library
***POP1
**BLOCKS
ID_Blocks [Blocks]
ID_Standard_blocks [Windows and Doors]$I=block_library.windows_doors $I=*
***TOOLBARS
***IMAGE
**WINDOWS_DOORS
[Windows and Doors]
[win-door]^C^Cinsert;win-door;
[525-2x6-case]^C^Cinsert;525-2x6-case;
[525-2x4-case]^C^Cinsert;525-2x4-case;
[1225-2x6-case]^C^Cinsert;1225-2x6-case;
[1225-2x4-case]^C^Cinsert;1225-2x4-case;
[1525-2x6-case]^C^Cinsert;1525-2x6-case;
[1525-2x4-case]^C^Cinsert;1525-2x4-case;
[1775-2x6-case]^C^Cinsert;1775-2x6-case;
[1775-2x4-case]^C^Cinsert;1775-2x4-case;
[1511-2x6-slider]^C^Cinsert;1511-2x6-slider;
[1511-2x4-slider]^C^Cinsert;1511-2x4-slider;
[1816-2x6-slider]^C^Cinsert;1816-2x6-slider;
[1816-2x4-slider]^C^Cinsert;1816-2x4-slider;
[1828-2x6-slider]^C^Cinsert;1828-2x6-slider;
[1828-2x4-slider]^C^Cinsert;1828-2x4-slider;
[pocketdoor]^C^Cinsert;pocketdoor;
// End of AutoCAD LT menu file - C:\Program Files\AutoCAD LT
R. Robert Bell wrote in message
news:9C1745ED646D6368D49927970E637A8F@in.WebX.maYIadrTaRb...
menu
slide
being
| use
| | Acad version LT97
| | Sincerely,
| | Brent U
Message 4 of 13
What happens when you unload this menu. Are the comments in your file
correct (they word-wrapped on the post)? Why the empty ***TOOLBARS?
news:C2DC1C00D21F96867022062DCABF8A39@in.WebX.maYIadrTaRb...
| ***POP1
| **BLOCKS
| ID_Blocks [Blocks]
| ***TOOLBARS
| ***IMAGE
| **WINDOWS_DOORS
| [Windows and Doors]
Message 5 of 13
I unloaded everything, so all I had was a File menu...it still does it.
What happens is the right mouse does whatever the last key on the keyboard
was pressed. So If I type in line, and right click, it adds an e. If I hit
enter, then right click, it enters.
Brent U
news:F3E2336ACCECF8CD7B54A4D3160BD863@in.WebX.maYIadrTaRb...
| | ***POP1
| | **BLOCKS
| | ID_Blocks [Blocks]
$I=*
| | ***TOOLBARS
| | ***IMAGE
| | **WINDOWS_DOORS
| | [Windows and Doors]
Message 6 of 13
Weird. Could it be your mouse driver?
news:9F9D17B2762C9FA8F84C9708151CC845@in.WebX.maYIadrTaRb...
hit
| Brent U
Message 7 of 13
Tried that. I've tried everything short of re-installing acad. Which I
can't do, and the tech guy that works here is gone for the next week.
I tell you, this is really slowing me down!
news:E042794F5F7AA8B9D836D63B378E3982@in.WebX.maYIadrTaRb...
keyboard
| hit
| | Brent U
Message 8 of 13
Wierd! Don't mean to interrupt. Robert has asked the right questions.
I understand that you
a. have used menuload to load your menu and subsequently
unloaded all menus.
b. did not use menu command to load the menu in the first place.
c. haven't changed the
1. right click customization in the options command.
2. mouse settings in the operating system driver.
d. don't have any autoloading lisp files that affect the mouse settings.
e. are sure that the version of the menu that you attached is the one
being loaded and not another one with the same name in
a directory earlier in the search path.
If above is true, suggest you delete the acad.mns, acad.mnc, and use
menu command to reload acad.mnu. Check your mouse then. If works,
then load your menu with menuload. Delete empty toobars section.
hit
> Brent U
Message 9 of 13
why cant YOU do it.. do not re-install acad, just repair autocad. get the disk, ctrl+alt+del to
close every program (except EXPLORER) and insert the disk, then do the repair option.
Please scroll and read previous posts, this way you will not post the same exact question, or look
at the AutoDesk discussion group listings for other groups.
http://support01.autodesk.com/Discussiongroups.asp
Jonathan Baker
R&R Engineers-Surveyors, Inc.
Denver, Colorado
news:3AA10DA721BF5A0C74EB29010F613229@in.WebX.maYIadrTaRb...
| keyboard
| | hit
| | | Brent U
Message 10 of 13
I can't get the disc. I am not allowed to touch it. It's not easy being
the low man on the totem pole.
I'll try reloading the mnu file and see what happens.
Brent
Jon Baker wrote in message
news:C20F784F3F53EB5C7F6AC61EF1931705@in.WebX.maYIadrTaRb...
repair option.
| Jonathan Baker
| Denver, Colorado
it.
| | keyboard
If I
| | | hit
| | | | Brent U
Message 11 of 13
No luck. I've even asked nicely, but the computer won't listen.
Brent Upton wrote in message
news:E8FFB4DC15174DCD225F4BFA7299AB22@in.WebX.maYIadrTaRb...
| Brent
the
| repair option.
same
| | Jonathan Baker
| | Denver, Colorado
I
does
| it.
| | | keyboard
| If I
| | | | hit
| | | | | Brent U
Message 12 of 13
I fixed it. My acad support path was pointing to a file that didn't exist
someplace off in la-la land.
I just set it to the aclt.mnu template file, got that message that says
doing this will overwrite any custom da-da-da I ok'd it, restarted acad and
viola, it works!
Wonder why it would magically erase the entry from the preferences like
that?
Brent
Doug Broad wrote in message
news:3CDC192C3231412F9A50D421CA13AA23@in.WebX.maYIadrTaRb...
| unloaded all menus.
keyboard
| hit
| > Brent U
Message 13 of 13
Glad your back in business.
Doug Broad
news:73948A409613D5E9640D7EE983F8391E@in.WebX.maYIadrTaRb...
and
> viola, it works!
> that?
> Brent
”Boost
