Ribbon Panel Display Order
2 REPLIES 2
chicodon
838 Views, 2 Replies
I need a Guru.
In the CUI, I created a new panel and added it to a Ribbon Tab I have in my custom workspace.
I want the panels to display in a certain order left to right so I moved the new panel to the position I wanted in the Tab.
Upon saving and leaving the CUI, it displays at the end position in the ribbon and not in the position I wanted.
I went back into the CUI and manually moved it to where I want by customizing my workspace.
Upon saving it still displays at the end position.
I can drag it to the position I want but I wouldn't want a user to have to do that.
What am I doing wrong?
Thanks a lot
2 REPLIES 2
chicodon
in reply to: chicodon
Never mind. I should just move the panel and save the workspace. Duh!
I'm using C3D 2014 and I have the same problem... can you break down how you solved this?
”Boost
