I am looking for a lisp that I can run that will update the drawing revision to the next revision up. only problem I have is the tag for line 1-1 is the same for line 2-1, 3-1, 4-1, etc, and line 1-2 is the same as line 2-2, 3-2, 4-2, etc.
there is no varance in the tag just the prompt.
please help.
please help.
I probably wrote half a dozen of code for this task. I can post a couple of them here but i need to see your block darryl.m.bowen, that way i can post the appropriate code to work on you block
