I'm trying to create a lisp routine where It will create a layer for the delta that is needed and at the same time adds the delta. I get delta revisions often and it takes time to add a new layer and a new delta for each plan. I would like to create a routine that creates the the new layer based on the revision number.
For example if I get a revision 2 I would like to have a lisp routine that creates a new layer but asks what number i would like to use, once the new layer gets created the revcloud command would run, I use polylines around my revisions then change them to cloud with the revcloud command. after i pick my polylines to be changed to clouds then it would add a delta block that is in an attribute and it lets me put the number of the revision i want. At the end I would have a new layer, a cloud around my revision and a delta corresponding to the revision number i'm currently working with.
I have a routine that creates the new layer, sets it current, and starts the revcloud command where i can pick the objects to change to clouds, after that I'm stuck, I'm not sure how to tell AutoCAD that after the selection is made to start the insert command to insert that delta attribute block. I mean the routine ends after i pick my objects, I tried doint the delta first but i ran into the same issue since my routine ends after AutoCAD ask me to pick a location to put my delta block.
I need to figure a way to tell AutoCAD that after something is picked or selected then to continue with the lisp routine without ending it. I atteched an example of what I have for anyone to review. Any help is highly apprecitaed and thanks in advance.
Solved by Kent1Cooper. Go to Solution.
Solved by Kycau. Go to Solution.
I piecemailed my research to get me this..
(DEFUN C:RVC (/ *Error*) (defun *Error* (strErr) (setvar "TextEval" txtev) (SETVAR 'OSMODE #OSM) (setvar "expert" ept) (setvar "CmdEcho" echo) (setvar "clayer" lay1) (setvar "attdia" rc1) (setvar "attreq" rc2) (princ) ) ;_ closes ERROR EXCEPTION defun (setq ;saves current SYSTEM VARIABLES #OSM (GETVAR 'OSMODE) echo (getvar "CmdEcho") txtev (getvar "TextEval") ept (getvar "expert") lay1 (getvar "clayer") rc1 (getvar "attdia") rc2 (getvar "attreq") ) ;;; =================================== Sets the current System Variables (command "_.UNDO" "Group") (setvar "attdia" 0) (setvar "attreq" 1) (SETVAR 'OSMODE 0) (SETVAR 'CMDECHO 0) (SETVAR 'TEXTEVAL 1) (SETVAR 'EXPERT 4) ;;; =================================== (if (= plc nil) (setq plc 1) (SETQ PLC TMP1) ) (princ "\nWhat is the Current Revision: <") (princ plc) (princ ">: ") (setq tmp1 (getint)) (if (/= tmp1 nil) (setq plc tmp1) ) (setq tmp1 plc a1 (abs plc) a2 (rtos a1 2 0) a3 (strcat "-REV" a2) ) ;;; =================================== Sets the current layer (if (tblsearch "layer" a3) ;if true then... (setvar "clayer" a3) ;if false, then (command "._LAYER" "_MAKE" a3 "_color" "10" a3 "") ) ;end IF ;;; =================================== Creates Revcloud (setvar 'REVCLOUDMINARCLENGTH 0.125) (setvar 'REVCLOUDMAXARCLENGTH 0.125) (SETVAR 'CMDECHO 1) (initcommandversion) (command-s "._revcloud" ; "A" 0.125 "" PAUSE ) (SETVAR 'CMDECHO 0) ;;; =================================== Inserts Revision Delta (setq pt (getpoint "\nPick insertion point for the Revision Triangle: " ) ) (command "_.insert" "../../00_CAD Library/06_Blocks/06.04_Civil Design/ZE-REV.dwg" ;path the revision delta pt "" "" "" a2 ) ;;; =================================== Restores Previous Settings (setvar "TextEval" txtev) (setvar "expert" ept) (setvar "CmdEcho" echo) (setvar "clayer" lay1) (setvar "attdia" rc1) (setvar "attreq" rc2) (SETVAR 'OSMODE #OSM) ;;; =================================== Closes LISP (*error* nil) (princ) ;quiet exit )
It creates "_rev#" layer in color 10.
inserts the revcloud and block on that layer, then reverts the layer to the previously current layer.
