Im new to lisp and I've reached a point that I just can't seem to get past. Im trying to select text from a specific point on the drawing and set the value of that text as a variable to return later. Im stuck at selecting the text and saving the value. I've tried the vla-get-textstring method shown in acadauto.chm file but it shows how to create a text and then return it. Any help would be greatly appreciated.
(setq p1 (list 30.4248 2.2476)); top point of selection box for detailer name in title block
(setq p2 (list 31.5532 2.4448)); bot point of selection box for detailer name in title block
(setq p3 (list 25.2794 1.3583)); mid point of detailer name in rev box
(setq detname (???? p1 p2))
(command "text" "S" "STANDARD" "J" "M" p3 0.1 0 detname)
Jeremy
Solved by Lee_Mac. Go to Solution.
Solved by hmsilva. Go to Solution.
Something like this perhaps.
(setq p1 (list 30.4248 2.2476)); top point of selection box for detailer name in title block (setq p2 (list 31.5532 2.4448)); bot point of selection box for detailer name in title block (setq p3 (list 25.2794 1.3583)); mid point of detailer name in rev box (if (setq txt (ssget "C" p1 p2 '((0 . "TEXT"))));; creates a selectionb set using a crossing selection, see if a (progn (setq detname (cdr (assoc 1 (entget (ssname txt 0)))));; gets the text string (command "text" "S" "STANDARD" "J" "M" p3 0.1 0 detname) );; progn );; if
HTH
Henrique
Jeremy, something you may want to think about...
I gather from your post that you are trying to read text from a specific location on a drawing border & recreate it at another location?
This being the case...the code you have posted & the solution which you have been offered can produce unpredictable results. Your approach assumes that the text source & destination positions will always be the same. However, what happens if a user moves or places the drawing border at a different location than that which is expected? A far better approach would be to have the drawing border as a block with pre-defined & uniquely named attributes at the source & destination positions. Then you could test to see if the block is present in the drawing & if so look for the specific attributes, get the value of one & then write it into the other. As you have said, you are fairly new to AutoLisp and I am not trying to pick your code apart or demean you in any way, but sometimes when you assume & write "hard coded" values into your programs you can end up with unpredictable results. One vital lesson I learned when writing code is to understand that you cannot make assumption...everything must be tested & varified before trying to perform an action. If you would like to discuss this further, I am quite happy for you to PM me & I will do my best to help you along.
Steve
@JeremyD79 wrote:
Henrique I appreciate you helping with the code. As soon as I can I will test it out.
You're welcome, Jeremy.
Keep in mind that using "ssget" function with the crossing or window option, requires that the selected object be visible, to do this you may use a zoom command just before the selection,
i.e.
using your points
(command "_zoom" "_w" p1 p2)
or a zoom extents, then do the selection stuff, and then
(command "_zoom" "_P")
restores the previous zoom.
Hope that helps
Henrique
Indeed, any graphical selection method will only select those objects visible within the drawing area at the time of selection.
Here is an alternative method that should perform successfully independent of zoom:
(defun c:test ( / txt ) (if (setq txt (ssget "_X" '( (0 . "TEXT") (-4 . ">=,>=") (10 30.4248 2.2476) (-4 . "<=,<=") (10 31.5532 2.4448) ) ) ) (entmake (list '(00 . "TEXT") '(07 . "Standard") '(10 25.2794 1.3583) '(11 25.2794 1.3583) '(72 . 4) '(73 . 0) '(40 . 0.1) (assoc 1 (entget (ssname txt 0))) ) ) ) (princ) )
Here are some links to help you understand the code:
@ JeremyD79
Happy to help!
@ Lee Mac
Nice approach Lee!
Just a thought, should not be used a active layout filter, if we have multiple instances in multiple layouts the result may not be the desired...
Henrique
@JeremyD79 wrote:
Henrique and Lee_Mac thanks for both of your help. Both of your programs worked exactly as I was needing. Also Lee I appreciate the links. Thanks again.
Jeremy
You're welcome Jeremy
@hmsilva wrote:Nice approach Lee!
Thank you Henrique
Good point about the layout filter, perhaps the following code would be better:
(defun c:test ( / txt ) (if (setq txt (ssget "_X" (list '(0 . "TEXT") '(-4 . ">=,>=") '(10 30.4248 2.2476) '(-4 . "<=,<=") '(10 31.5532 2.4448) (if (= 1 (getvar 'cvport)) (cons 410 (getvar 'ctab)) '(410 . "Model") ) ) ) ) (entmake (list '(00 . "TEXT") '(07 . "Standard") '(10 25.2794 1.3583) '(11 25.2794 1.3583) '(72 . 4) '(73 . 0) '(40 . 0.1) (assoc 1 (entget (ssname txt 0))) ) ) ) (princ) )
Lee_mac wrote:
Thank you Henrique
You're welcome, Lee
As usual, a very good solution!
Henrique
Still yet another method for catching desired objects (a little more complicated, but does not require blocks with attributes).
Each object has a handle. The DFX code for this handle is 5. The value assigned to DFX 5 will never change (so I am told).
Investigate VLAX-LDATA-GET and VLAX-LDATA-PUT to retrieve and store the object's handle in the file's dictionary.
If you want to store and retrieve multiple handles, investigate LIST.
The selection set SSGET "X" will require a filter - use the value that was stored from the dictionary.
Test to see if the selection set has the object.
If it does - you now have your desired object where you can now extract the data you need.
Rereading your post a second time it looks like you are trying to erase the existing text and adding a new text object in it's place???
>>Im trying to select text from a specific point on the drawing...
Look into ENTMOD and (CDR (ASSOC 1 (ENTGET (SSNAME [your selection set] 0)))) to rewrite DFX code 1, which is the text value (display).
If there is no text to select, then do as the first paragraph suggests but choose another object (such as a line) and POLAR (from DFX 10)
to the desired location you want to place the new text object.
Since you are a beginner, enter the following on the command line and select an object:
(entget (car (entsel "Select an object: ")))
Do you see all the DFX codes? Learn what each means and you will be an expert in no time...
Hope this helps.
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
@scot-65 wrote:Investigate VLAX-LDATA-GET and VLAX-LDATA-PUT to retrieve and store the object's handle in the file's dictionary.
Note that the filter list argument of the ssget function cannot be used to filter for entity handles:
The ssget function recognizes all group codes except entity names (group -1), handles (group 5), and xdata codes (groups greater than 1000).
Scot-65
