In AutoCAD MEP and other verticals, they have Notes that can be attached to entities via the Properties dialog box.
I'm trying to retrieve that information using MEP 2012. The information from this link, if it worked in the past, doesn't appear to work now: http://forums.autodesk.com/t5/Visual-LISP-AutoLISP-and-General/get-Extended-Data-from-Aec-Wall/td-p/...
In the example from the link the user was able to get entitiy data like this:
((-1 . ) (0 . "AEC_TEXT_NOTE") (5 . "BC4") (102 . "{ACAD_REACTORS") (330 . ) (102 . "}") (330 . ) (100 . "AecDbObject") (102 . "{AEC_SUBOBJECT") (300 . "AecImpObj") (100 . "AecImpObj") (3 . "") (102 . "AEC_SUBOBJECT}") (102 . "{AEC_NULLOBJECT}") (100 . "AecDbTextNote") (1 . "hejhejhej2"))
I drew a simple line then attached a note to the entity. Trying the code from the example above, my result does not contain the AecDbTextNote information.
((-1 . <Entity name: 7ffff284210>) (0 . AEC_TEXT_NOTE) (5 . 6FBE9) (102 .
{ACAD_REACTORS) (330 . <Entity name: 7ffff284200>) (102 . }) (330 . <Entity
name: 7ffff284200>))((-1 . <Entity name: 7ffff284210>) (0 . "AEC_TEXT_NOTE") (5
. "6FBE9") (102 . "{ACAD_REACTORS") (330 . <Entity name: 7ffff284200>) (102 .
"}") (330 . <Entity name: 7ffff284200>))
Help appreciated.
Craig
What are you hoping to do with this information once you obtain it? There are built-in ways to access this information without programming (multleaders, schedules, tags, etc.) AFAIK
Also keep in mind that you're dealing with a vertical platform... Not everything is exposed to DXF, or LISP generally... Often times in my work (with Civil 3D), if even possible to access certain Objects via LISP, and External COM Object interface is required, if not stepping up into the .NET API (and even then, not everything is exposed to .NET API, and I still end up using DllImports, or COM; but that's another discussion).
HTH
"How we think determines what we do, and what we do determines what we get."
Also worthy of note, is that the post you linked to in the OP is from 2006... Certainly there have been significant changes from then to your AMEP 2012 version. :thumbsup:
Cheers
Thanks for the posts to date.
We have a large number of custom notes for all sorts of entities and need to retrieve that information. For various reasons, lisp would be the ideal choice.
I realize the post I referenced is old. It's unfortunate that it appears to have worked in the past but something must have changed with future releases. I was hoping someone would know if the information is still accessible somewhere via lisp. And while it is a vertical, the note information appears to be used across several vertical platforms from what I can glean from other posts so I was hoping the data would be more readily accessible.
Craig
What motivates me to dig into the ACA/AMEP dictionary mess(from a LISP perspective) is to have an application where I would ever use it. I can already do everything that I need with tags and schedules. Perhaps if you could share more about how you could use this information in a way that tags and schedules don't, it might be worth investing a couple of hours to track the answer down. Otherwise it's time down a rabbit hole.
You might pose the same question on the .NET forum as every time I asked anything about customizing ACA/AMEP, all the experts said there was no supported LISP access. The language/platform you need to use is one of the .NET languages. Blackbox's repy is similar. Go to .NET and maybe get a solution.
While I obviously cannot speak with any authority on the specific task of obtaining the 'notes' from a given entity, I'd be a bit shocked if there wasn't an COM Object interface (i.e., Visual LISP, or VBA) that could be used to save the 1+ year of self-teaching the basics of the AutoCAD .NET API, let alone the complexities of vertical(s).
Worth some Googling... That's all I'm saying... Lord knows you won't find much of that in the online help. LoL
Cheers
For the additional information I like to utilize the:
(vlax-ldata-put dict key data [private])
(vlax-ldata-get dict key [default-data] [private])
(vlax-ldata-list dict [private])
(vlax-ldata-delete dict key [private])
functions. So far they have not let me down.
I have interacted personally with the ACA designers (by email) in the past and they have assured me that there is supported activeX access and no intention to provide one in the future. ActiveX, I believe, only exposes part these features. I'm not saying that it isn't possible to find the needle in the haystack by brute force looking. The properties and methods of these objects however are directly exposed via .net in the form that those objects were intended to be manipulated with.
There is also no logic or help documenation for tracking these features down.
@Anonymous wrote:I have interacted personally with the ACA designers (by email) in the past and they have assured me that there is supported activeX access and no intention to provide one in the future. ActiveX, I believe, only exposes part these features. I'm not saying that it isn't possible to find the needle in the haystack by brute force looking. The properties and methods of these objects however are directly exposed via .net in the form that those objects were intended to be manipulated with.
If I am understanding you correctly, the ACA designers have confirmed that there is not a supported ActiveX (COM) accessible interface for Visual LISP/VBA?
No worries; I only thought to suggest one abuse Google for a few to confirm, but that's good enough for me. :thumbsup:
Especially since these APIs have been exposed to .NET, I'd then simply code up some LispFunction Methods as needed if this had to be done via LISP... One is then only relegated to the ResultBuffer return types when 'getting' something from a given Entity.
Cheers
When a drawing with LDATA is opened on a computer which doesn't automatically call (vl-load-com) during the open, or when you double-click the DWG file to open it, you get a proxy object warning unless that dialog has been supressed. One of the reasons I moved away from LDATA and into dedicated Extension dictionaries and XRecords.
