Visual LISP, AutoLISP and General Customization
retreive cell data from excel file
6 REPLIES 6
spykat
977 Views, 6 Replies
I would like to be able to retreive data from a sepcified cell, in a specified worksheet, from an excel file.
I don't have any clue how to connect to an excel file and read the data. I've searched the forum and found nothing that help me understand. Most seems to think you already had an understanding but I'm starting from the beginning.
Can somebody help me?
6 REPLIES 6
in reply to: spykat
You need to use the Link to range option from the data link options while trying to create a table.  See attached.
Lee_Mac
in reply to: spykat
This by Terry Miller may help you.
spykat
I guess I should have stated that I need to do it from lisp
in reply to: spykat
No problem!  The better information you provide up front, the better help you will get.  As they say in this business "There are several ways to skin a kat".  You just have to find the one that works best for you.
in reply to: spykat
I'm trying to do something similar but just for select cells in excel to show its info in either an Mtext or attribute definition format and not in a table.  I'm not sure if this is possible.  Specifically I would like to do is link information from my information sheet (like project name or location) directly into the title block in the corresponding location.  The idea was that if i was able to use a relative path that I would do this in each job folder and each drawing generated in that folder would reflect that info.  I'm trying to create this in LT, so without a LISP program.
Any help would be appreciated.
mttlp
in reply to: spykat
vlax apply line error
”Boost
