I am updating the tools on my office's tool palettes. I should mention I'm updating the names to include the suffix "Rev2". Because of the new block layout, the new icon images are too small to distinguish. How can I retain the original icon image as I update the tool palette?
Right click on the item in the toolpalette and select Properties. In the Tool Properties window, you'll see the image on the top left. Right click on the image and select Specify Image. I'm not sure if this will be overwritten by updating the tool image or not. Hope that helps.
Let me give a simple example of the issue.
I have a block containing a circle. The block is named “Circle Rev1”. Using this block to create a palette tool, it creates an icon with a circle and lightning bolt. Later I update the block to include a seven character attribute to the right of the circle. The block is renamed to “Circle Rev2” and the tool on the palette is revised along with the icon. Now the icon image contains a circle with adjacent seven text characters. As you would expect, the icon is now too small to decipher what it is. I would prefer to update the tool and keep not have the icon change with each revision. I hope this explains the issue I’m encountering.
@RocksterB wrote:
Wow! I think I've stumped the experts!
Hi RocksterB,
was not gccdaemon's solution suitable?
Or, you didn't understood gccdaemon's advise?
Let's see if I can help...
Tool Palletes.
When you add a .dwg to a Tool Pallet, AutoCAD creates by default two images from the file, FileName32.PNG and FileName64.PNG for that specific tool...
If you proceed as gccdaemon as described in is reply
'Right click on the item in the toolpalette and select Properties. In the Tool Properties window, you'll see the image on the top left. Right click on the image and select Specify Image.'
or at the pallete, select tool, right click and Specify Image, and select one of the default image (i.e. FileName64.PNG) AutoCAD will erase the other image, and the selected image becomes the image for that specific tool.
If you change the data inside de original file, or even specify a new source file for that tool, the image becomes unalterable until you right click on tool and select Remove specified image.
Hope that helps
Henrique
Thanks for the feedback. So, is there a method to revise the block without changing the original image? That's what I need to do.
You're welcome.
Yes.
As described in my previous post...
Henrique
Thanks for your help guys. I'll try your suggestyions on Monday. Also, what i may do is restore the orgiginal copy of the images back to the same image folder.
