Replacing characters in a text file.
Dear all:
I solved the following Lisp routine chore. I have this csv file of coordinates (and many more) that comes from a total station:1,100,100,10,50
2,100,200,12,50
3,200,200,12,50
4,200,100,10,51
and should replace the code after the last comma like this:1,100,100,10,.50
2,100,200,12,.50
3,200,200,12,.50
4,200,100,10,..50
To be able to generate the topographic map.
And I have this code but does not work properly:
(defun c:cod (/ filename fileopenr readline)
(if (setq filename (getfiled "!!! SELECT *.csv FILE COORDINATE:... ¡¡¡" "c:/" "csv" 0 ))
(progn (setq fileopenr (open filename "w"))
(while (setq readline (read-line fileopenr))
(while (vl-string-position ",50" readline)
(setq readline (vl-string-subst ",.50" ",50" readline))
(write-line readline fileopenr)
(close filename)
So please help me debug Lisp code (or Visual Lisp or VBA?)
@latinman328 wrote:.... I have this csv file of coordinates (and many more) that comes from a total station:1,100,100,10,50
2,100,200,12,50
3,200,200,12,50
4,200,100,10,51
2,100,200,12,.50
3,200,200,12,.50
4,200,100,10,..50
....(progn (setq fileopenr (open filename "w"))
(close filename)....
You can't read from and write to the same file. If you open a file for writing, and the file name exists, it overwrites it with an initially empty file. If you want to write something to a file that already exists, without wiping out its current content, I think your only choice is the "append" option, which will add to the end but won't replace lines already in the file. I think you will need two files for this, to read from one and write to another. [Also, (close) should take the variable name that the file name returned by the (open) function was saved into, rather than the file name itself.] Try something like this [untested]:
(defun ....
(if ....
(progn
(setq
fileR (open filename "r")
fileW (open {...build edited-file path and name...} "w")
); setq
(while
(setq readline (read-line fileR))
;; [I assume (while) instead of (if) is in case there's more than one ",50" in a line]
); while
(write-line readline fileW); put into new file, whether edited or not, so all lines will be in it
); while
); progn
); if
(close fileR)
(close fileW)
); defun
