Visual LISP, AutoLISP and General Customization
Replace similiar objects with a new object
12 REPLIES 12
Message 1 of 13
331 Views, 12 Replies
I have this dxf that has a bunch of points....only the points aren't really points; they are a series of tiny lines that form a little circle. So i have tons of these circles/closed polylines that need to be converted to points. I have been searching the forms but no luck. Any help would greatly be appreciatted.
12 REPLIES 12
Message 2 of 13
Whether they are lots of little lines or closed polylines, you can
determine their center(close enough, anyhow) by taking the average value
of the (assoc 10) codes of their vertices, put a point there, and erase
the original stuff.
So the question is, how many of these pseudo-points are there? A couple
of dozen you can do by selecting the lines by window for each point, but
a couple of hundred would get right tedious. Maybe get them all on a
layer of their own, figure out how to turn them into closed polylines,
and then process all the resulting polylines as above.
-Bill
Message 3 of 13
Can you post a sample dwg of what you have? I had to do something similar a
few years back with a few thousand dwgs so I have a few lisp that may work
for you but may need adjusting.
Message 4 of 13
stevor
A common problem that can usually be automated, like the Auto in Autocad.
The programming for a geometry recognition would go something like:
1. search for the appropriate size line by ssget or by stepping thru the entity dbase.
2. search about its end for lie sized lines until a loop is found.
3. estimate a center in the mention manor, or the equivalent.
4. create the new point
5. delete or change the layer of the lines
S
Message 5 of 13
stevor
S
Message 6 of 13
Although I have programming experience, I am still new to LISP....so work with me.....
I attached the file........ this is the original so you will have to make polylines and close the "lil circles"....easy enough
The closest thing I can find online is this, but I need to get the points going for the center of the "lil circles":
This puts a selected object where ever there are points.......
(defun c:Rp()
(setq ss (ssget "x" (list (cons 0 "points"))))
(setq inc 0)
(setq obj (car (entsel "\nSelect an object to locate at each point: ")))
(setq orgpnt (cdr (assoc '10 (entget obj))))
(while (setq node (ssname ss inc)))
(setq topnt (cdr (assoc '10 (entget node))))
(command "copy" obj "" orgpnt topnt)
(setq inc (1+ inc)))
(princ "\nDone")
I was using this because ultimately I would like to be able to copy a "station symbol"(object) to each of these points.
Edited by: cadsys08 on Oct 16, 2008 4:46 PM Edited by: cadsys08 on Oct 16, 2008 6:47 PM
Message 7 of 13
Can't download the attachment for some reason.
Message 8 of 13
Hi cadsys08,
I've  downloladed the drawing and I was able
to select all the polylines and PEDIT all of them in one shot, using a fuzz
factor of 0.0000001 for the JOIN option. This resulted in 282 closed
polylines. Now, I assume that it's kind of easy to replace each of them one by
one by a circle using 3 vertices from each polyline, delete the
polyline and then adding a point in the center of the circle and then
removing the circle.
Try to do this by your self, and if you have
problems, come back.
Although
polylines and close the "lil circles"....easy enough The closest thing I can
"lil circles": This puts a selected object where ever there are points.......
(defun c:Rp() (setq ss (ssget "x" (list (cons 0 "points")))) (setq inc 0)
(setq obj (car (entsel "\nSelect an object to locate at each point: "))) (setq
orgpnt (cdr (assoc '10 (entget obj)))) (while (setq node (ssname ss inc)))
(setq topnt (cdr (assoc '10 (entget node)))) (command "copy" obj "" orgpnt
topnt) (setq inc (1+ inc))) (princ "\nDone") ) I was using this because
of these points. Edited by: cadsys08 on Oct 16, 2008 4:46 PM
Message 9 of 13
Try this file.......
Yeah I figured out that using a 2 pnt circle and click opposing verticies makes an nice centered circle....then snap a point to center of circle, then delete polyline. I can easily make a macro to do this, but sometimes the file might have hundreds, maybe thousands of "points"....I need to be able to do this operation to a selection set...not one at a time.
I have a line plot associated with these points.....it might be easier to write LISP to put circles(objects) at each endpoint of the lines.....just a thought.
Edited by: cadsys08 on Oct 17, 2008 12:30 AM
I was able to use the code to snab the objects to the ends of the lines by simply changing (setq ss (ssget "x" (list (cons 0 "points")))) to (setq ss (ssget "x" (list (cons 0 "line")))). Works like a champ, except for it seems to repeat the process 5 times.....so i end up having to use overkill command to go back and clean up the overlapping objects(no big deal).
Still would be nice if someone could refine this code.......ultimately what would be nice would be like a find and replace for objects.
Edited by: cadsys08 on Oct 17, 2008 1:26 AM
Message 10 of 13
devitg
As all are14 sided poly , make a selection set ,
(setq all-poly-ss (ssget "x" '( ( 0 . "lw*") (8 . "MARKS") )))
and convert each poly-ent to a poly obj
by
(vl-load-com)
(setq acad* (vlax-get-acad-object)) ;_ ACAD program
(setq adoc (vla-get-activedocument acad*)) ;_ the current
(vla-get-activeselectionset adoc)
then
by
(setq end-par (vlax-curve-getEndParam poly-obj))
(setq p1 (vlax-curve-getPointAtParam poly-obj 0))
(setq p2 (vlax-curve-getPointAtParam poly-obj (/ end-par 2.0)))
get the mid point
(setq cent (mapcar '* '(0.5 0.5 0.5) (mapcar '+ p1 p2)))
now you can make the point , and erase the poly .
Hope it is clear .
Message 11 of 13
Hi again cadsys08,
Based on the suggestion made by devitg, here is a
function that will replace the initial entities with points. From your
drawing, it comes out that the "li'l circles" are made up of
small LINE segments. So I PEDIT them first, then I get some representative
points on the new polylines and then I place a point on the determined cennter,
erasing the polyline in the end. The JOIN part takes a little longer with large
number of "li'l circles" so you have to be patient 🙂 If you need, you can
define a command to be used with this function (see the code
below).
HTH
size=2>;;;=================================================
(defun C:SPT ()(SubstPoints)(princ))
(defun SubstPoints ( /
size=2>
activedocument
size=2>
old_cmdecho
size=2>
all_lines
size=2>
all_polys
size=2>
center
size=2>
  (vl-load-com)
  (setq activedocument (vla-get-activedocument
(vlax-get-acad-object)))
 (setq old_cmdecho (getvar
'cmdecho))
 (setvar 'cmdecho 0)
  (setq all_lines (ssget '((0 . "LINE")(8 .
"MARKS"))))
  (command "_.pedit" "_m" all_lines "" "_j" 0.0000001
  (ssget "X" '((0 .
"LWPOLYLINE")(8 . "MARKS")))
  (setq all_polys (vla-get-activeselectionset
activedocument))
  (setvar 'pdmode 34)
  (setvar 'pdsize
-1)
  (vlax-for poly all_polys
face=Arial size=2>
    (setq center
      (mapcar
'* '(0.5 0.5 0.5)
        (mapcar
0)
poly
(vlax-curve-getEndParam poly)
2.0)
(vla-addpoint
      (vla-get-modelspace
activedocument)
      (vlax-3d-point (trans center 0
1))
(vla-delete poly)
  (setvar 'cmdecho
old_cmdecho)
  (princ)
size=2>;;;=====================================================
Try
this file....... Yeah I figured out that using a 2 pnt circle and click
need to be able to do this operation to a selection set...not one at a time. I
Edited by: cadsys08 on Oct 17, 2008 12:30 AM I was able to use the code to
the overlapping objects(no big deal). Still would be nice if someone could
replace for objects. Edited by: cadsys08 on Oct 17, 2008 1:26 AM
Message 12 of 13
WOW! Thanks guys! that code is way over my head...I would have never figured it out on my own.
I will get back to you soon and let you know how it works out.
Thanks again!
Message 13 of 13
I made some tests and I've realised that because
the circles are aproximated by line segments, the first solution places the
points slightly "out of tune", i.e. shifted from the center of a real circle
that would replace the initial "circle like" shape. So if you need greater
accuracy, here is a modified version, that creates a circle over the initial
shape, places a point in the center of the new circle, then erases the circle
and the initial shape.
activedocument
old_cmdecho
all_lines
all_polys
pt1
pt2
pt3
circle
(vl-load-com)
'cmdecho))
 (setvar 'cmdecho 0)
  (setq all_lines (ssget '((0 . "LINE")(8 . "MARKS"))))
(command "_.pedit" "_m" all_lines "" "_j" 0.0000001 "")
(ssget "X" '((0 . "LWPOLYLINE")(8 . "MARKS")))
  (setq all_polys
(vla-get-activeselectionset activedocument))
  (setvar 'pdmode
34)
  (setvar 'pdsize -1)
  (vlax-for poly
all_polys
    (setq pt1 (vlax-curve-getPointAtParam poly 0))
    (setq pt2
(/ (vlax-curve-getEndParam poly) 3)
    (setq pt3
(* (/ (vlax-curve-getEndParam poly) 3) 2)
    (command "_.circle" "_3p" pt1 pt2
pt3)
    (setq circle (vlax-ename->vla-object
(entlast)))
(vla-addpoint
      (vla-get-modelspace
activedocument)
      (vlax-get-property circle
'center)
    (vla-delete circle)
    (vla-delete
poly)
  (setvar 'cmdecho old_cmdecho)
(princ)
WOW!
on my own. I will get back to you soon and let you know how it works out.
Thanks again!
”Boost
