Active Contributor
0 Kudos
Post 1 of 8
Repeating Break at Single Point
641 Views, 7 Replies
11-07-2011 04:06 PM
Hi All,
I'm creating the following macro:- (defun C:BK () (command "_BREAK" PAUSE "_F" PAUSE "@" )(princ)) to add to a shortcut key lisp file and then I want it to repeat... How do I make it repeat?
I want it to do the same as this:- *^C^C_break \_f \@ but as a shortcut key in a lisp format.
Cheers,
Andy
671 Kudos
Post 2 of 8
Re: Repeating Break at Single Point
11-07-2011 06:37 PM in reply to: andit
One simple way:
(defun C:BK ()
  (while T
    (command "_BREAK" PAUSE "_F" PAUSE "@")
You could add error handling so you wouldn't see the "error: Function cancelled" message when you hit Escape to stop it.
Kent Cooper
Active Contributor
0 Kudos
Post 3 of 8
11-07-2011 08:57 PM in reply to: Kent1Cooper
Thankyou Kent that what I was looking for, may I ask how the "(while T" works to repeat the command?
Cheers,
Andy
335 Kudos
Post 4 of 8
11-08-2011 03:40 AM in reply to: Kent1Cooper
Kent1Cooper wrote:
One simple way:
Or:
(defun c:bk nil
    (while (vl-cmdf "_.break" pause "_F" pause "@")) (princ)
(vl-load-com)
So that no error handler is required.
Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
Expert Elite
With Mathematics there is the possibility of perfect rigour, so why settle for less?
671 Kudos
Post 5 of 8
11-08-2011 05:02 AM in reply to: andit
See (while) in the AutoLISP Reference.  As long as the 'testexpr' argument doesn't evaluate to nil, it keeps doing what is asked for after that.  T is the symbol for True, and never evaluates to nil [unless you commit the crime of using it for a variable name and overriding that].  It could be anything that doesn't, such as
(while 1 (command ....
Kent Cooper
Valued Mentor
18 Kudos
Post 6 of 8
11-08-2011 05:03 AM in reply to: andit
Also, you can use one GETPOINT, with or without object snaps, to assign both of the break points.
S
671 Kudos
Post 7 of 8
11-08-2011 05:11 AM in reply to: Lee_Mac
Lee_Mac wrote:
Or:
I don't think it would have occurred to me to use a (while) function without any what-to-do-then expression(s) after the test expression, but sure enough, they are optional.
Kent Cooper
Valued Mentor
51 Kudos
Post 8 of 8
11-08-2011 06:04 AM in reply to: Kent1Cooper
I've been using this for quite some time, you could just replace the if with while...
(defun c:BA (/ e p)
  ;; Break Object @ Point
  ;; Alan J. Thompson, 03.26.09 / 08.23.10
  (setvar 'errno 0)
  (if (while (and (not e) (/= 52 (getvar 'errno))) (setq e (entsel "\nSelect object to break: ")))
    (progn (setq p (cond ((getpoint "\nSpecify point to break @ <Selection Point>: "))
                         ((osnap (cadr e) "_near"))
           (vl-cmdf "_.break" e "_F" "_non" p "_non" p)
  (princ)
