Hi All,
I'm creating the following macro:- (defun C:BK () (command "_BREAK" PAUSE "_F" PAUSE "@" )(princ)) to add to a shortcut key lisp file and then I want it to repeat... How do I make it repeat?
I want it to do the same as this:- *^C^C_break \_f \@ but as a shortcut key in a lisp format.
Cheers,
Andy
@Anonymous wrote:....
One simple way:
(defun C:BK ()
(while T
(command "_BREAK" PAUSE "_F" PAUSE "@")
You could add error handling so you wouldn't see the "error: Function cancelled" message when you hit Escape to stop it.
Thankyou Kent that what I was looking for, may I ask how the "(while T" works to repeat the command?
Cheers,
Andy
@Kent1Cooper wrote:
One simple way:
Or:
(defun c:bk nil (while (vl-cmdf "_.break" pause "_F" pause "@")) (princ) ) (vl-load-com)
So that no error handler is required.
@Anonymous wrote:Thankyou Kent that what I was looking for, may I ask how the "(while T" works to repeat the command?
See (while) in the AutoLISP Reference. As long as the 'testexpr' argument doesn't evaluate to nil, it keeps doing what is asked for after that. T is the symbol for True, and never evaluates to nil [unless you commit the crime of using it for a variable name and overriding that]. It could be anything that doesn't, such as
(while 1 (command ....
@Lee_Mac wrote:....Or:
I don't think it would have occurred to me to use a (while) function without any what-to-do-then expression(s) after the test expression, but sure enough, they are optional.
I've been using this for quite some time, you could just replace the if with while...
(defun c:BA (/ e p) ;; Break Object @ Point ;; Alan J. Thompson, 03.26.09 / 08.23.10 (setvar 'errno 0) (if (while (and (not e) (/= 52 (getvar 'errno))) (setq e (entsel "\nSelect object to break: "))) (progn (setq p (cond ((getpoint "\nSpecify point to break @ <Selection Point>: ")) ((osnap (cadr e) "_near")) ) ) (vl-cmdf "_.break" e "_F" "_non" p "_non" p) ) ) (princ) )
Hi, your lisp has been pretty useful for me but, How do you stop it? it seems like I am in an infinite loop I can't get out of.
I like your use of "errno." But your selection may be an unbreakable object such as text.
Here's a version I wrote a while back. It presumes that anything that is offsetable can be broken...
(defun C:BreakAt ( / *error* cmdecho E Obj P) ;; Created (12-05-06) by John F. Uhden (or *acad* (setq *acad* (vlax-get-acad-object))) (or *doc* (setq *doc* (vla-get-ActiveDocument *acad*))) (defun *error* (error) (if (= (type cmdecho) 'INT)(setvar "cmdecho" cmdecho)) (sssetfirst) (vla-endundomark *doc*) (cond ((not error)) ((wcmatch (strcase error) "*QUIT*,*CANCEL*")) (1 (princ (strcat "\nERROR: " error))) ) (princ) ) (vla-endundomark *doc*) (vla-startundomark *doc*) (setq cmdecho (getvar "cmdecho")) (setvar "cmdecho" 0) (command "_.expert" (getvar "expert")) (and (setq E (car (entsel "\nPick object to break: "))) (sssetfirst nil (ssadd E)) (setq Obj (vlax-ename->vla-object E)) (or (vlax-method-applicable-p Obj 'Offset) (prompt "\nCan not break this object") ) (setq P (getpoint "\nSelect break point: ")) (setq P (vlax-curve-getclosestpointto Obj P)) (command "_.break" E P "@") ) (*error* nil) ) (defun c:BA ()(C:BreakAt))
John F. Uhden
