Visual LISP, AutoLISP and General Customization
rename xref in tool palette in multiple drawings
1 REPLY 1
marlance
431 Views, 1 Reply
Is there a lisp that will rename xrefs in tool palette (not the file name) in multiple drawings?
regards,
roldan
1 REPLY 1
hmsilva
in reply to: marlance
 Hi Roldan,
this is not the program you're looking for, is just a 'demo' and a starting point.
If the xref names are like those in example 'Some-Name-Final Name' the code will remove part of the name until the last '-' at the xref name and will try to put the xref with that name if no other with the same name.
To process more than one dwg, do a search at 'Search This Board' for batch or process,  and you'll get many examples how to accomplish that.
(defun c:demo (/ name newn pos)
  (vlax-For blk (vla-Get-Blocks (vla-Get-ActiveDocument (vlax-Get-Acad-Object)))
    (if (and (= (vla-Get-IsXref blk) :vlax-True)
             (wcmatch (setq name (vla-get-Name blk)) "*-*")
      (progn
        (setq pos  (vl-string-position (ascii "-") name nil T)
              newn (substr name (+ pos 2))
        (if (not (vl-catch-all-error-p
                   (vl-catch-all-apply '(lambda () (vla-put-Name blk newn)))
          (vla-reload blk)
  (princ)
Hope that helps
Henrique
”Boost
