Is there a lisp that will rename xrefs in tool palette (not the file name) in multiple drawings?
regards,
roldan
Solved by hmsilva. Go to Solution.
Hi Roldan,
this is not the program you're looking for, is just a 'demo' and a starting point.
If the xref names are like those in example 'Some-Name-Final Name' the code will remove part of the name until the last '-' at the xref name and will try to put the xref with that name if no other with the same name.
To process more than one dwg, do a search at 'Search This Board' for batch or process, and you'll get many examples how to accomplish that.
(defun c:demo (/ name newn pos) (vlax-For blk (vla-Get-Blocks (vla-Get-ActiveDocument (vlax-Get-Acad-Object))) (if (and (= (vla-Get-IsXref blk) :vlax-True) (wcmatch (setq name (vla-get-Name blk)) "*-*") ) (progn (setq pos (vl-string-position (ascii "-") name nil T) newn (substr name (+ pos 2)) ) (if (not (vl-catch-all-error-p (vl-catch-all-apply '(lambda () (vla-put-Name blk newn))) ) ) (vla-reload blk) ) ) ) ) (princ) )
Hope that helps
Henrique
