As I said, there should be no opened document when you do the drag&drop
stuff in AutoCAD, but if it happens to have an opened document, just make
sure you don't drop the DWG files over the graphic screen (this is like
inserting them as blocks), but rather in the Command area.
Humans are born with a wide horizon.
As time goes by, the horizon narrows and
narrows, until it becomes a point of view.
a écrit dans le message de news:
6307084@discussion.autodesk.com...
Thank you for your suggestion, but I got lost at "and then just drag and
drop..."
