I get an AutoCAD drawing from my conveyor manufacturer who have buried a block (tagname) in all of their conveyor blocks.
The only way to remove them is to manually use BEDIT and erase the tagname block. Very time consuming
Is there a way through Autolisp to search all blocks in a drawings and if the tagname block is part of the definition of the conveyor block, erase the tagname block or redefine the conveyor block without the tagname block.
Solved by Lee_Mac. Go to Solution.
How about just re-defining the "tagname" block into something inconsequential, like a node (point) or a small circle on a noplot layer?
Alternatively, my Delete Blocks program will delete all references of one or more blocks from a drawing.
Excellent - you're welcome!
lgabriel wrote:
To all above suggestions, thank you for your responses. The DELBLOCKS.lsp does exactly what I need.
I marked Lee's suggestion as the solution if you don't mind.
Perfect for a file with 300 blocks nested in 300 other blocks! saved me a lot of time. 10/10 would recommend
