Visual LISP, AutoLISP and General Customization
remove xref or block
15 REPLIES 15
Message 1 of 16
490 Views, 15 Replies
I have this code, when opening a dwg its suppose to find the format, for
example, with the name of "fmta1 or fmta1r14" and replace it with a format
called "fmta12k6".
However im trying to modify it to where if its an xref with the names above,
to detach it, purge it and then insert the block of "fmta2k6" but its if its
a block with those names to just redefine it to the format "fmta2k6"
i have multiple formats that have different names as you see in the code
can anyone help me out on how to get to what im after?
if i want to just detach and purgethe xref and i remove the redefine command
it works good
and vice versa however i would like to make it work no matter what the
circumstances are
any help is greatly appreciated
(SETQ SSB (SSGET "x"
(LIST
(CONS 2 "*FMT*")
(cons 10 '(0.0 0.0 0.0))
(SETQ DS (GETVAR "DIMSCALE"))
(setq ss (ssget "X" (list (cons 0 "INSERT"))))
(setq C 0)
(repeat (sslength ss)
(setq entity (ssname ss C))
(setq elist (entget entity))
(setq blockname (strcase (cdr (assoc 2 elist))))
(setq blockcheck (substr blockname 1 5))
(setq fmt (strcat blockcheck "2K6"))
(if (or (= blockname "FMTA1R14")
(= blockname "FMTA1")
(= blockname "FMTB1R14")
(= blockname "FMTB1")
(= blockname "FMTC1R14")
(= blockname "FMTC1")
(= blockname "FMTM1R14")
(= blockname "FMTM1")
(= blockname "FMTS1R14")
(= blockname "FMTS1")
(= blockname "FMTW1R14")
(= blockname "FMTW1")
(progn
(command "-XREF" "d" blockname)
(command "-purge" "b" blockname "n")
(command "-insert"(strcat blockname "=" fmt))
(command)
(command "-insert" fmt "0,0" ds ds "0")
(setq C (+ C 1))
15 REPLIES 15
Message 2 of 16
Add this function:
(defun is_xref (name / ename data)
(and name
(setq ename (tblobjname "block" name))
(setq data (entget ename))
(= 4 (logand 4 (cdr (assoc 70 data))))
Then:
(progn
(if (is_xref blockname)
); if
(command)
Bob
Message 3 of 16
Bob,
Where am I adding the first part?
wrote in message news:5782187@discussion.autodesk.com...
Add this function:
(and name
Then:
(progn
); if
(command)
Bob
Message 4 of 16
well i realized where it goes but it doesnt work
thanks for the help anyway
wrote in message news:5782288@discussion.autodesk.com...
Bob,
Add this function:
(and name
Then:
(progn
); if
(command)
Bob
Message 5 of 16
i guess it helps to say why it dont work
when its an xref it doesnt do anything
and goes right to trying to redefine the first block in the block list
instead of the block im after
wrote in message news:5782334@discussion.autodesk.com...
Bob,
Add this function:
(and name
Then:
(progn
); if
(command)
Bob
Message 6 of 16
I might be helpful if you specify exactly what you want
it to do.
Case IS Xref ..... do what ?
Case IS NOT Xref .... do what ?
Bob
Message 7 of 16
if its an xref (detach it, purge it and insert as a block)
if its a block (redefine it)
(command "-insert"(block=block))
(command)
wrote in message news:5782457@discussion.autodesk.com...
it to do.
Bob
Message 8 of 16
In that case, make your 'change' loop look like:
(progn
(progn
); progn
); if
(if (not (is_xref blockname))
(progn
(command)
); progn
); if
Bob
Message 9 of 16
sorry still not working
the code below returns "22" in the command line
(SETQ SS (SSGET "x"
(LIST
(CONS 2 "*FMT*")
(setq C 0)
(and name
(progn
(if (is_xref fmtx)
(progn
); progn
); if
(progn
(command)
); progn
); if
(setq C (+ C 1))
wrote in message news:5782644@discussion.autodesk.com...
(progn
(progn
); progn
); if
(progn
(command)
); progn
); if
Bob
Message 10 of 16
i take that back, it partially works (typo in the code)
it works with the xref
it doesnt redefine an old block to the new block
wrote in message news:5782712@discussion.autodesk.com...
(SETQ SS (SSGET "x"
(LIST
(CONS 2 "*FMT*")
(setq C 0)
(and name
(progn
(if (is_xref fmtx)
(progn
); progn
); if
(progn
(command)
); progn
); if
(setq C (+ C 1))
(progn
(progn
); progn
); if
(progn
(command)
); progn
); if
Bob
Message 11 of 16
Move the (defun is_xref .. function way up-top, before anything else.. and
this line:
(if (is_xref fmtx)
has variable fmtx .. which I don't see defined.
Change it to:
Bob
Message 12 of 16
i realized the fmtx part was wrong when i made the last post
but it didnt help
and by moving the defun part to the top didnt do anything different
still only works when its an xref, doesnt redefine the old block
wrote in message news:5782725@discussion.autodesk.com...
this line:
(if (is_xref fmtx)
Change it to:
Bob
Message 13 of 16
whats weird is it says its changed but when i list the block it still
displays as the old block
here is what it says
Command: (load "update")
-insert Enter block name or [?] : FMTA1R14=FMTA12K6 Duplicate
Block "FMTA1R14" redefined
Units: Unitless Conversion: 1.00000
Specify insertion point or [Basepoint/Scale/X/Y/Z/Rotate]:
Command: 110
Command: LIST
Select objects: 1 found
Select objects:
BLOCK REFERENCE Layer: "3"
Space: Model space
Handle = f176
Block Name: "fmta1r14"
at point, X= 0'-0" Y= 0'-0" Z= 0'-0"
X scale factor: 6.00000
Y scale factor: 6.00000
rotation angle: 0d0'0.00"
Z scale factor: 6.00000
Scale uniformly: No
Allow exploding: Yes
wrote in message news:5783195@discussion.autodesk.com...
but it didnt help
this line:
(if (is_xref fmtx)
Change it to:
Bob
Message 14 of 16
Does it LOOK the old way? Does REGEN or REGENALL fix that, perhaps?
Or do you mean the Block Name is still listed as the old one? That won't be "fixed" by redefining
the block. You would need to RENAME it, too.
Kent Cooper
wrote...
Command: 110
Command: LIST
Select objects:
Space: Model space
Handle = f176
Scale uniformly: No
but it didnt help
this line:
(if (is_xref fmtx)
Change it to:
Bob
Message 15 of 16
umm... $hit...
i thought it was supposed to change the block name as well as the
information in the block?
ok call me stupid
Bob I appreciate your help & I appolgize for wasting your time its been
working since your 3rd reply.
Kent thanks for smacking me in the head. I have understood it in a wrong way
for a while.
"Kent Cooper" wrote in message
news:5783231@discussion.autodesk.com...
Kent Cooper
wrote...
Command: 110
Command: LIST
Select objects:
Space: Model space
Handle = f176
Scale uniformly: No
but it didnt help
this line:
(if (is_xref fmtx)
Change it to:
Bob
Message 16 of 16
I prefer to think of it as just giving you a little nudge....wouldn't want to hurt anybody....
Kent Cooper
wrote...
umm... $hit...
for a while.
”Boost
